<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Modbus IP]]></title><description><![CDATA[<p dir="auto">I tested the modbus IP data source with Twido PLC. All data type points  possible are not supported in twido so i tested the ones which are supported.(2 byte datatypes). So i can tell Telemecanique Twido is one supported HW.</p>
<p dir="auto">Found a problem with Holding registers with binary data type. The data reading works well but setting such data point value there appears popup dialog with text "Error" (and nothing more). Could someone explaind what  causing this or is there some bug?</p>
]]></description><link>https://forum.mango-os.com/topic/212/modbus-ip</link><generator>RSS for Node</generator><lastBuildDate>Thu, 17 Sep 2026 00:28:00 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/212.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 19 Oct 2009 17:50:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Modbus IP on Thu, 22 Oct 2009 04:21:11 GMT]]></title><description><![CDATA[<p dir="auto">Nice catch. This was a bug in Modbus4J in the WriteMaskRegister failover. I've checked the fix into the CVS repo.</p>
]]></description><link>https://forum.mango-os.com/post/2785</link><guid isPermaLink="true">https://forum.mango-os.com/post/2785</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Thu, 22 Oct 2009 04:21:11 GMT</pubDate></item><item><title><![CDATA[Reply to Modbus IP on Wed, 21 Oct 2009 16:07:23 GMT]]></title><description><![CDATA[<p dir="auto">I am testing with Ubuntu 9.04. After the first post I removed open java and installed sun java(if it has anything to do with anything). I repeated the test, stopped tomcat, removed logs and started again. This time i found out there is a og named mango.log  :oops: i was just checkin catalina....log and localhost...log under tomcat logs folder.</p>
<p dir="auto">mango.log content is ```</p>
<p dir="auto">startup date [Wed Oct 21 18:44:04 EEST 2009]; root of context hierarchy<br />
INFO  2009-10-21 18:50:50,155 (org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.destroySingletons:392) - Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@1742700: defining beans [CompoundEventsDwr,DataPointDetailsDwr,DataPointEditDwr,DataSourceEditDwr,DataSourceListDwr,EmportDwr,EventHandlersDwr,EventsDwr,MailingListsDwr,MiscDwr,PointHierarchyDwr,PublisherEditDwr,PublisherListDwr,ReportsDwr,ScheduledEventsDwr,SystemSettingsDwr,UsersDwr,ViewDwr,WatchListDwr,localeResolver,messageSource]; root of factory hierarchy<br />
INFO  2009-10-21 18:52:06,155 (org.springframework.web.context.ContextLoader.initWebApplicationContext:189) - Root WebApplicationContext: initialization started<br />
INFO  2009-10-21 18:52:06,568 (org.springframework.context.support.AbstractApplicationContext.prepareRefresh:412) - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@ff2413: display name [Root WebApplicationContext]; startup date [Wed Oct 21 18:52:06 EEST 2009]; root of context hierarchy<br />
INFO  2009-10-21 18:52:07,195 (org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions:323) - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext.xml]<br />
INFO  2009-10-21 18:52:07,593 (org.springframework.context.support.AbstractApplicationContext.obtainFreshBeanFactory:427) - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@ff2413]: org.springframework.beans.factory.support.DefaultListableBeanFactory@1de9ac4<br />
INFO  2009-10-21 18:52:08,138 (org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons:414) - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@1de9ac4: defining beans [CompoundEventsDwr,DataPointDetailsDwr,DataPointEditDwr,DataSourceEditDwr,DataSourceListDwr,EmportDwr,EventHandlersDwr,EventsDwr,MailingListsDwr,MiscDwr,PointHierarchyDwr,PublisherEditDwr,PublisherListDwr,ReportsDwr,ScheduledEventsDwr,SystemSettingsDwr,UsersDwr,ViewDwr,WatchListDwr,localeResolver,messageSource]; root of factory hierarchy<br />
INFO  2009-10-21 18:52:08,678 (org.springframework.web.context.ContextLoader.initWebApplicationContext:209) - Root WebApplicationContext: initialization completed in 2446 ms<br />
INFO  2009-10-21 18:52:08,681 (com.serotonin.mango.MangoContextListener.contextInitialized:73) - Mango context starting<br />
INFO  2009-10-21 18:52:10,374 (com.serotonin.mango.db.DerbyAccess.initializeImpl:69) - Initializing derby connection manager<br />
INFO  2009-10-21 18:52:17,157 (com.serotonin.mango.db.upgrade.DBUpgrade.checkUpgrade:76) - Starting instance with version 1.7.0<br />
INFO  2009-10-21 18:52:20,505 (org.quartz.simpl.SimpleThreadPool.initialize:258) - Job execution threads will use class loader of thread: main<br />
INFO  2009-10-21 18:52:20,628 (org.quartz.core.SchedulerSignalerImpl.&lt;init&gt;:63) - Initialized Scheduler Signaller of type: class org.quartz.core.SchedulerSignalerImpl<br />
INFO  2009-10-21 18:52:20,630 (org.quartz.core.QuartzScheduler.&lt;init&gt;:215) - Quartz Scheduler v.1.6.3 created.<br />
INFO  2009-10-21 18:52:20,645 (org.quartz.simpl.RAMJobStore.initialize:141) - RAMJobStore initialized.<br />
INFO  2009-10-21 18:52:20,647 (org.quartz.impl.StdSchedulerFactory.instantiate:1224) - Quartz scheduler 'DefaultQuartzScheduler' initialized from default resource file in Quartz package: 'quartz.properties'<br />
INFO  2009-10-21 18:52:20,649 (org.quartz.impl.StdSchedulerFactory.instantiate:1228) - Quartz scheduler version: 1.6.3<br />
INFO  2009-10-21 18:52:20,656 (org.quartz.core.QuartzScheduler.start:461) - Scheduler DefaultQuartzScheduler_$_NON_CLUSTERED started.<br />
INFO  2009-10-21 18:52:23,432 (com.serotonin.mango.rt.RuntimeManager.startDataSource:256) - Data source 'Systeemi' started<br />
INFO  2009-10-21 18:52:25,250 (com.serotonin.mango.rt.RuntimeManager.startDataSource:256) - Data source 'Twido' started<br />
INFO  2009-10-21 18:52:25,699 (com.serotonin.mango.rt.RuntimeManager.startDataSource:256) - Data source 'Virtuaali' started<br />
INFO  2009-10-21 18:52:27,078 (com.serotonin.mango.MangoContextListener.contextInitialized:97) - Mango context started<br />
INFO  2009-10-21 18:52:27,422 (org.springframework.web.servlet.FrameworkServlet.initServletBean:257) - FrameworkServlet 'springDispatcher': initialization started<br />
INFO  2009-10-21 18:52:27,437 (org.springframework.context.support.AbstractApplicationContext.prepareRefresh:412) - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@6adb31: display name [WebApplicationContext for namespace 'springDispatcher-servlet']; startup date [Wed Oct 21 18:52:27 EEST 2009]; parent: org.springframework.web.context.support.XmlWebApplicationContext@ff2413<br />
INFO  2009-10-21 18:52:27,443 (org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions:323) - Loading XML bean definitions from ServletContext resource [/WEB-INF/springDispatcher-servlet.xml]<br />
INFO  2009-10-21 18:52:27,624 (org.springframework.context.support.AbstractApplicationContext.obtainFreshBeanFactory:427) - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@6adb31]: org.springframework.beans.factory.support.DefaultListableBeanFactory@1424b7b<br />
INFO  2009-10-21 18:52:27,887 (org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons:414) - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@1424b7b: defining beans [viewResolver,defaultMessageCodeResolver,publicUrlMappings,compoundEventsController,dataPointDetailsController,dataPointEditController,dataSourceEditController,dataSourceListController,emportController,eventHandlersController,eventsController,helpController,loginController,logoutController,mailingListsController,pointHierarchyController,publicViewController,publisherEditController,publisherListController,reportChartController,reportsController,scheduledEventsController,sqlController,systemSettingsController,usersController,viewsController,viewEditController,watchListController,webcamLiveFeedController,multipartResolver,commonData]; parent: org.springframework.beans.factory.support.DefaultListableBeanFactory@1de9ac4<br />
INFO  2009-10-21 18:52:29,527 (org.springframework.web.servlet.FrameworkServlet.initServletBean:276) - FrameworkServlet 'springDispatcher': initialization completed in 2103 ms<br />
INFO  2009-10-21 18:52:29,552 (<a href="http://org.directwebremoting.util.CommonsLoggingOutput.info:51" rel="nofollow ugc">org.directwebremoting.util.CommonsLoggingOutput.info:51</a>) - DWR Version 2.0.1 starting.<br />
INFO  2009-10-21 18:52:29,568 (<a href="http://org.directwebremoting.util.CommonsLoggingOutput.info:51" rel="nofollow ugc">org.directwebremoting.util.CommonsLoggingOutput.info:51</a>) - - Servlet Engine: Apache Tomcat/6.0.18<br />
INFO  2009-10-21 18:52:29,570 (<a href="http://org.directwebremoting.util.CommonsLoggingOutput.info:51" rel="nofollow ugc">org.directwebremoting.util.CommonsLoggingOutput.info:51</a>) - - Java Version:   1.6.0_16<br />
INFO  2009-10-21 18:52:29,572 (<a href="http://org.directwebremoting.util.CommonsLoggingOutput.info:51" rel="nofollow ugc">org.directwebremoting.util.CommonsLoggingOutput.info:51</a>) - - Java Vendor:    Sun Microsystems Inc.<br />
INFO  2009-10-21 18:52:30,392 (<a href="http://org.directwebremoting.util.CommonsLoggingOutput.info:51" rel="nofollow ugc">org.directwebremoting.util.CommonsLoggingOutput.info:51</a>) - Probably not an issue: org.jdom.Document is not available so the jdom converter will not load. This is only an problem if you wanted to use it.<br />
INFO  2009-10-21 18:52:30,403 (<a href="http://org.directwebremoting.util.CommonsLoggingOutput.info:51" rel="nofollow ugc">org.directwebremoting.util.CommonsLoggingOutput.info:51</a>) - Probably not an issue: org.jdom.Element is not available so the jdom converter will not load. This is only an problem if you wanted to use it.<br />
INFO  2009-10-21 18:52:48,071 (com.serotonin.mango.web.filter.LoggedInFilter.doFilter:55) - Denying access to secure page for session id 0FFA1048778DC448535C0A58C3904EBB, uri=/watch_list.shtm<br />
INFO  2009-10-21 18:52:50,642 (<a href="http://org.directwebremoting.util.CommonsLoggingOutput.info:51" rel="nofollow ugc">org.directwebremoting.util.CommonsLoggingOutput.info:51</a>) - Exec: MiscDwr.terminateLongPoll()<br />
INFO  2009-10-21 18:53:03,629 (<a href="http://org.directwebremoting.util.CommonsLoggingOutput.info:51" rel="nofollow ugc">org.directwebremoting.util.CommonsLoggingOutput.info:51</a>) - Exec: MiscDwr.initializeLongPoll()<br />
INFO  2009-10-21 18:53:03,675 (<a href="http://org.directwebremoting.util.CommonsLoggingOutput.info:51" rel="nofollow ugc">org.directwebremoting.util.CommonsLoggingOutput.info:51</a>) - Exec: WatchListDwr.init()<br />
INFO  2009-10-21 18:53:03,720 (<a href="http://org.directwebremoting.util.CommonsLoggingOutput.info:51" rel="nofollow ugc">org.directwebremoting.util.CommonsLoggingOutput.info:51</a>) - Exec: WatchListDwr.getDateRangeDefaults()<br />
INFO  2009-10-21 18:53:05,301 (<a href="http://org.directwebremoting.util.CommonsLoggingOutput.info:51" rel="nofollow ugc">org.directwebremoting.util.CommonsLoggingOutput.info:51</a>) - Exec: MiscDwr.doLongPoll()<br />
INFO  2009-10-21 18:53:10,845 (<a href="http://org.directwebremoting.util.CommonsLoggingOutput.info:51" rel="nofollow ugc">org.directwebremoting.util.CommonsLoggingOutput.info:51</a>) - Exec: MiscDwr.resetWatchlistState()<br />
INFO  2009-10-21 18:53:11,762 (<a href="http://org.directwebremoting.util.CommonsLoggingOutput.info:51" rel="nofollow ugc">org.directwebremoting.util.CommonsLoggingOutput.info:51</a>) - Exec: MiscDwr.doLongPoll()<br />
INFO  2009-10-21 18:53:12,591 (<a href="http://org.directwebremoting.util.CommonsLoggingOutput.info:51" rel="nofollow ugc">org.directwebremoting.util.CommonsLoggingOutput.info:51</a>) - Exec: MiscDwr.doLongPoll()<br />
INFO  2009-10-21 18:53:23,150 (<a href="http://org.directwebremoting.util.CommonsLoggingOutput.info:51" rel="nofollow ugc">org.directwebremoting.util.CommonsLoggingOutput.info:51</a>) - Exec: MiscDwr.doLongPoll()<br />
INFO  2009-10-21 18:53:25,915 (<a href="http://org.directwebremoting.util.CommonsLoggingOutput.info:51" rel="nofollow ugc">org.directwebremoting.util.CommonsLoggingOutput.info:51</a>) - Exec: WatchListDwr.setPoint()<br />
ERROR 2009-10-21 18:53:26,059 (com.serotonin.web.dwr.ExceptionDetectionFilter.doFilter:29) - DWR invocation exception<br />
com.serotonin.modbus4j.exception.IllegalDataTypeException: Only binary values can be read from Coil and Input ranges<br />
at com.serotonin.modbus4j.ModbusLocator.validate(ModbusLocator.java:60)<br />
at com.serotonin.modbus4j.ModbusLocator.&lt;init&gt;(ModbusLocator.java:23)<br />
at com.serotonin.modbus4j.ModbusLocator.&lt;init&gt;(ModbusLocator.java:27)<br />
at com.serotonin.modbus4j.ModbusMaster.getValue(ModbusMaster.java:66)<br />
at com.serotonin.modbus4j.ModbusMaster.getValue(ModbusMaster.java:58)<br />
at com.serotonin.modbus4j.ModbusMaster.setHoldingRegisterBit(ModbusMaster.java:388)<br />
at com.serotonin.modbus4j.ModbusMaster.setValue(ModbusMaster.java:170)<br />
at com.serotonin.mango.rt.dataSource.modbus.ModbusDataSource.setPointValue(ModbusDataSource.java:179)<br />
at com.serotonin.mango.rt.RuntimeManager.setDataPointValue(RuntimeManager.java:399)<br />
at com.serotonin.mango.rt.RuntimeManager.setDataPointValue(RuntimeManager.java:384)<br />
at com.serotonin.mango.web.dwr.BaseDwr.setPointImpl(BaseDwr.java:176)<br />
at com.serotonin.mango.web.dwr.BaseDwr.setPoint(BaseDwr.java:166)<br />
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)<br />
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)<br />
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)<br />
at java.lang.reflect.Method.invoke(Method.java:597)<br />
at org.directwebremoting.impl.ExecuteAjaxFilter.doFilter(ExecuteAjaxFilter.java:34)<br />
at org.directwebremoting.impl.DefaultRemoter$1.doFilter(DefaultRemoter.java:428)<br />
at com.serotonin.mango.util.LocalizationFilter.doFilter(LocalizationFilter.java:52)<br />
at com.serotonin.web.dwr.ExceptionDetectionFilter.doFilter(ExceptionDetectionFilter.java:23)<br />
at com.serotonin.mango.web.dwr.util.LoggedInAjaxFilter.doFilter(LoggedInAjaxFilter.java:39)<br />
at org.directwebremoting.impl.DefaultRemoter.execute(DefaultRemoter.java:431)<br />
at org.directwebremoting.impl.DefaultRemoter.execute(DefaultRemoter.java:283)<br />
at org.directwebremoting.servlet.PlainCallHandler.handle(PlainCallHandler.java:52)<br />
at org.directwebremoting.servlet.UrlProcessor.handle(UrlProcessor.java:101)<br />
at org.directwebremoting.servlet.DwrServlet.doPost(DwrServlet.java:146)<br />
at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)<br />
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)<br />
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)<br />
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)<br />
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)<br />
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)<br />
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)<br />
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)<br />
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)<br />
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)<br />
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)<br />
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)<br />
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)<br />
at java.lang.Thread.run(Thread.java:619)<br />
WARN  2009-10-21 18:53:26,089 (org.directwebremoting.util.CommonsLoggingOutput.warn:67) - Method execution failed:<br />
WARN  2009-10-21 18:53:26,101 (org.directwebremoting.util.CommonsLoggingOutput.warn:59) - --Erroring: batchId[8] message[com.serotonin.modbus4j.exception.IllegalDataTypeException: Only binary values can be read from Coil and Input ranges]<br />
INFO  2009-10-21 18:53:27,545 (<a href="http://org.directwebremoting.util.CommonsLoggingOutput.info:51" rel="nofollow ugc">org.directwebremoting.util.CommonsLoggingOutput.info:51</a>) - Exec: MiscDwr.doLongPoll()<br />
INFO  2009-10-21 18:53:53,177 (<a href="http://org.directwebremoting.util.CommonsLoggingOutput.info:51" rel="nofollow ugc">org.directwebremoting.util.CommonsLoggingOutput.info:51</a>) - Exec: MiscDwr.doLongPoll()<br />
INFO  2009-10-21 18:53:56,648 (<a href="http://org.directwebremoting.util.CommonsLoggingOutput.info:51" rel="nofollow ugc">org.directwebremoting.util.CommonsLoggingOutput.info:51</a>) - Exec: WatchListDwr.setPoint()<br />
ERROR 2009-10-21 18:53:56,667 (com.serotonin.web.dwr.ExceptionDetectionFilter.doFilter:29) - DWR invocation exception<br />
WARN  2009-10-21 18:53:56,680 (org.directwebremoting.util.CommonsLoggingOutput.warn:67) - Method execution failed:<br />
WARN  2009-10-21 18:53:56,685 (org.directwebremoting.util.CommonsLoggingOutput.warn:59) - --Erroring: batchId[11] message[com.serotonin.modbus4j.exception.IllegalDataTypeException: Only binary values can be read from Coil and Input ranges]<br />
INFO  2009-10-21 18:53:57,637 (<a href="http://org.directwebremoting.util.CommonsLoggingOutput.info:51" rel="nofollow ugc">org.directwebremoting.util.CommonsLoggingOutput.info:51</a>) - Exec: MiscDwr.doLongPoll()<br />
INFO  2009-10-21 18:54:22,271 (<a href="http://org.directwebremoting.util.CommonsLoggingOutput.info:51" rel="nofollow ugc">org.directwebremoting.util.CommonsLoggingOutput.info:51</a>) - Exec: MiscDwr.doLongPoll()<br />
INFO  2009-10-21 18:54:26,571 (<a href="http://org.directwebremoting.util.CommonsLoggingOutput.info:51" rel="nofollow ugc">org.directwebremoting.util.CommonsLoggingOutput.info:51</a>) - Exec: MiscDwr.doLongPoll()</p>
<pre><code>
Regards
Jokke</code></pre>
]]></description><link>https://forum.mango-os.com/post/2784</link><guid isPermaLink="true">https://forum.mango-os.com/post/2784</guid><dc:creator><![CDATA[Jokke]]></dc:creator><pubDate>Wed, 21 Oct 2009 16:07:23 GMT</pubDate></item><item><title><![CDATA[Reply to Modbus IP on Wed, 21 Oct 2009 14:15:48 GMT]]></title><description><![CDATA[<p dir="auto">If there's no WriteMaskRegisterRequest being made again, there's nowhere else to go than "the hard way". Did you manage to get a stack trace of the problem? (The stuff in your snippet all has to do with Mango not being able to find a database - definitely unrelated.)</p>
]]></description><link>https://forum.mango-os.com/post/2783</link><guid isPermaLink="true">https://forum.mango-os.com/post/2783</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Wed, 21 Oct 2009 14:15:48 GMT</pubDate></item><item><title><![CDATA[Reply to Modbus IP on Wed, 21 Oct 2009 12:58:31 GMT]]></title><description><![CDATA[<p dir="auto">I made some investigation in the source code. It seems to go into the WriteMaskRegisterRequest in ModbusMaster.java. I Analysed the network traffic and mango sends once Modbus function 22 message. Twido is not supporting the function so it responds "exception code 1 Illegal function".  When trying to set some other value it does not send this message again. So the slaveprofile saving probably is ok.</p>
<p dir="auto">In the code there is the "Hard way " option but that seems not reached. I assume there should be read request(F3) and write request(F6) sent.</p>
<p dir="auto">Regards<br />
Jokke</p>
]]></description><link>https://forum.mango-os.com/post/2782</link><guid isPermaLink="true">https://forum.mango-os.com/post/2782</guid><dc:creator><![CDATA[Jokke]]></dc:creator><pubDate>Wed, 21 Oct 2009 12:58:31 GMT</pubDate></item><item><title><![CDATA[Reply to Modbus IP on Mon, 19 Oct 2009 18:12:27 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for such a fast reply. Yes I am using 1.7.0. Ill try with the error reporting mechanism. I also check the logs.</p>
<p dir="auto">edit.<br />
Hope you received the error report. The log is quite long. I restarted tomcat and copied all print after it...```</p>
<p dir="auto">19.10.2009 21:17:14 org.apache.catalina.core.StandardContext listenerStart<br />
SEVERE: Exception sending context initialized event to listener instance of class com.serotonin.mango.MangoContextListener<br />
org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: Failed to start database '/var/lib/tomcat6/webapps/mango/../../mangoDB', see the next exception for details.<br />
at org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:82)<br />
at com.serotonin.mango.db.DerbyAccess.initializeImpl(DerbyAccess.java:77)<br />
at com.serotonin.mango.db.DatabaseAccess.initialize(DatabaseAccess.java:82)<br />
at com.serotonin.mango.MangoContextListener.databaseInitialize(MangoContextListener.java:248)<br />
at com.serotonin.mango.MangoContextListener.contextInitialized(MangoContextListener.java:85)<br />
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3843)<br />
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4338)<br />
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:791)<br />
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:771)<br />
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:525)<br />
at org.apache.catalina.startup.HostConfig.deployDirectory(HostConfig.java:926)<br />
at org.apache.catalina.startup.HostConfig.deployDirectories(HostConfig.java:889)<br />
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:492)<br />
at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1149)<br />
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:311)<br />
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:117)<br />
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1053)<br />
at org.apache.catalina.core.StandardHost.start(StandardHost.java:719)<br />
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1045)<br />
at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:443)<br />
at org.apache.catalina.core.StandardService.start(StandardService.java:516)<br />
at org.apache.catalina.core.StandardServer.start(StandardServer.java:710)<br />
at org.apache.catalina.startup.Catalina.start(Catalina.java:578)<br />
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)<br />
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)<br />
at java.lang.reflect.Method.invoke(Method.java:616)<br />
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:288)<br />
at org.apache.commons.daemon.support.DaemonLoader.start(DaemonLoader.java:177)<br />
Caused by: java.sql.SQLException: Failed to start database '/var/lib/tomcat6/webapps/mango/../../mangoDB', see the next exception for details.<br />
at org.apache.derby.impl.jdbc.SQLExceptionFactory40.getSQLException(Unknown Source)<br />
at org.apache.derby.impl.jdbc.Util.newEmbedSQLException(Unknown Source)<br />
at org.apache.derby.impl.jdbc.Util.seeNextException(Unknown Source)<br />
at org.apache.derby.impl.jdbc.EmbedConnection.bootDatabase(Unknown Source)<br />
at org.apache.derby.impl.jdbc.EmbedConnection.&lt;init&gt;(Unknown Source)<br />
at org.apache.derby.impl.jdbc.EmbedConnection30.&lt;init&gt;(Unknown Source)<br />
at org.apache.derby.impl.jdbc.EmbedConnection40.&lt;init&gt;(Unknown Source)<br />
at org.apache.derby.jdbc.Driver40.getNewEmbedConnection(Unknown Source)<br />
at org.apache.derby.jdbc.InternalDriver.connect(Unknown Source)<br />
at org.apache.derby.jdbc.EmbeddedDataSource.getConnection(Unknown Source)<br />
at org.springframework.jdbc.datasource.DataSourceUtils.doGetConnection(DataSourceUtils.java:113)<br />
at org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:79)<br />
... 32 more<br />
at org.apache.derby.impl.jdbc.SQLExceptionFactory.getSQLException(Unknown Source)<br />
at org.apache.derby.impl.jdbc.SQLExceptionFactory40.wrapArgsForTransportAcrossDRDA(Unknown Source)<br />
... 45 more<br />
Caused by: java.sql.SQLException: Java exception: ': java.nio.channels.OverlappingFileLockException'.<br />
at org.apache.derby.impl.jdbc.Util.javaException(Unknown Source)<br />
... 42 more<br />
Caused by: java.nio.channels.OverlappingFileLockException<br />
at sun.nio.ch.FileChannelImpl$SharedFileLockTable.checkList(FileChannelImpl.java:1215)<br />
at sun.nio.ch.FileChannelImpl$SharedFileLockTable.add(FileChannelImpl.java:1117)<br />
at sun.nio.ch.FileChannelImpl.tryLock(FileChannelImpl.java:923)<br />
at java.nio.channels.FileChannel.tryLock(FileChannel.java:978)<br />
at org.apache.derby.impl.io.DirFile4.getExclusiveFileLock(Unknown Source)<br />
at org.apache.derby.impl.store.raw.data.BaseDataFileFactory.privGetJBMSLockOnDB(Unknown Source)<br />
at org.apache.derby.impl.store.raw.data.BaseDataFileFactory.run(Unknown Source)<br />
at java.security.AccessController.doPrivileged(Native Method)<br />
at org.apache.derby.impl.store.raw.data.BaseDataFileFactory.getJBMSLockOnDB(Unknown Source)<br />
at org.apache.derby.impl.store.raw.data.BaseDataFileFactory.boot(Unknown Source)<br />
at org.apache.derby.impl.services.monitor.BaseMonitor.boot(Unknown Source)<br />
at org.apache.derby.impl.services.monitor.TopService.bootModule(Unknown Source)<br />
at org.apache.derby.impl.services.monitor.BaseMonitor.startModule(Unknown Source)<br />
at org.apache.derby.iapi.services.monitor.Monitor.bootServiceModule(Unknown Source)<br />
at org.apache.derby.impl.store.raw.RawStore.boot(Unknown Source)<br />
at org.apache.derby.impl.store.access.RAMAccessManager.boot(Unknown Source)<br />
at org.apache.derby.impl.db.BasicDatabase.bootStore(Unknown Source)<br />
at org.apache.derby.impl.db.BasicDatabase.boot(Unknown Source)<br />
at org.apache.derby.impl.services.monitor.BaseMonitor.bootService(Unknown Source)<br />
at org.apache.derby.impl.services.monitor.BaseMonitor.startProviderService(Unknown Source)<br />
at org.apache.derby.impl.services.monitor.BaseMonitor.findProviderAndStartService(Unknown Source)<br />
at org.apache.derby.impl.services.monitor.BaseMonitor.startPersistentService(Unknown Source)<br />
at org.apache.derby.iapi.services.monitor.Monitor.startPersistentService(Unknown Source)<br />
... 42 more<br />
19.10.2009 21:17:14 org.apache.catalina.core.ApplicationContext log<br />
INFO: Closing Spring root WebApplicationContext</p>
<pre><code></code></pre>
]]></description><link>https://forum.mango-os.com/post/2781</link><guid isPermaLink="true">https://forum.mango-os.com/post/2781</guid><dc:creator><![CDATA[Jokke]]></dc:creator><pubDate>Mon, 19 Oct 2009 18:12:27 GMT</pubDate></item><item><title><![CDATA[Reply to Modbus IP on Mon, 19 Oct 2009 17:58:06 GMT]]></title><description><![CDATA[<p dir="auto">Are you using version 1.7.0? If so, either turn on "report errors to Serotonin", or send any information/stack traces in the Tomcat console or log.</p>
]]></description><link>https://forum.mango-os.com/post/2780</link><guid isPermaLink="true">https://forum.mango-os.com/post/2780</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Mon, 19 Oct 2009 17:58:06 GMT</pubDate></item></channel></rss>
