<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problems Creating Datasource Modbus RTU]]></title><description><![CDATA[<p dir="auto">Hi, This is my problem, Modbus nodo scan is "ok", more, Modbus read Data "No response from slave 1". need help please, thank you very much</p>
]]></description><link>https://forum.mango-os.com/topic/2067/problems-creating-datasource-modbus-rtu</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 11:12:03 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2067.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 05 Jan 2016 23:35:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problems Creating Datasource Modbus RTU on Wed, 06 Jan 2016 19:41:03 GMT]]></title><description><![CDATA[<p dir="auto">I tried to create a connection in scadaBR and works perfect, attached image.<br />
<img src="https://camo.nodebb.org/432398c7682769ac893ec425f179aa2480c24b99?url=https%3A%2F%2Fi.imgur.com%2F5eAwp3r.jpg" alt="scadaBR.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/10774</link><guid isPermaLink="true">https://forum.mango-os.com/post/10774</guid><dc:creator><![CDATA[mtapia_vmt]]></dc:creator><pubDate>Wed, 06 Jan 2016 19:41:03 GMT</pubDate></item><item><title><![CDATA[Reply to Problems Creating Datasource Modbus RTU on Wed, 06 Jan 2016 19:30:08 GMT]]></title><description><![CDATA[<p dir="auto">You are testing reading 100 registers starting at 0.  Try reading 1 or 10 and make sure you are using a register you know has a value in it.  Every Modbus device is different so you need to look at the documentation on the device.</p>
]]></description><link>https://forum.mango-os.com/post/10773</link><guid isPermaLink="true">https://forum.mango-os.com/post/10773</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Wed, 06 Jan 2016 19:30:08 GMT</pubDate></item><item><title><![CDATA[Reply to Problems Creating Datasource Modbus RTU on Wed, 06 Jan 2016 19:28:02 GMT]]></title><description><![CDATA[<p dir="auto"><img src="https://camo.nodebb.org/d3fc6ddf99f8b47d163d2b55412d620bafb1afc4?url=https%3A%2F%2Fi.imgur.com%2FLtDuto1.jpg" alt="captura.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/10772</link><guid isPermaLink="true">https://forum.mango-os.com/post/10772</guid><dc:creator><![CDATA[mtapia_vmt]]></dc:creator><pubDate>Wed, 06 Jan 2016 19:28:02 GMT</pubDate></item><item><title><![CDATA[Reply to Problems Creating Datasource Modbus RTU on Wed, 06 Jan 2016 19:26:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joelhaggar" aria-label="Profile: JoelHaggar">@<bdi>JoelHaggar</bdi></a> said:</p>
<p dir="auto">There could be many different causes of this issue including bad wiring, baud rate, etc.</p>
<p dir="auto">Note that the Modbus Node Scan only works with certain devices. Did the scan find any slaves on the network. Maybe send a screenshot of your configuration.</p>
<p dir="auto">![upload-a66a6138-6609-4eaf-9b90-1d4744bcf360](uploading 100%)</p>
<p dir="auto">thank you very much Joel:<br />
Attached image, I also confirm that communication is correct<br />
Thanks for your answer.</p>
]]></description><link>https://forum.mango-os.com/post/10771</link><guid isPermaLink="true">https://forum.mango-os.com/post/10771</guid><dc:creator><![CDATA[mtapia_vmt]]></dc:creator><pubDate>Wed, 06 Jan 2016 19:26:39 GMT</pubDate></item><item><title><![CDATA[Reply to Problems Creating Datasource Modbus RTU on Wed, 06 Jan 2016 15:42:38 GMT]]></title><description><![CDATA[<p dir="auto">There could be many different causes of this issue including bad wiring, baud rate, etc.</p>
]]></description><link>https://forum.mango-os.com/post/10768</link><guid isPermaLink="true">https://forum.mango-os.com/post/10768</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Wed, 06 Jan 2016 15:42:38 GMT</pubDate></item></channel></rss>
