<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Excel Reports - Add a point functionality]]></title><description><![CDATA[<p dir="auto">It is almost impossible to add points to the excel report when there are thousands of points and the dropdown list is short and hard to use. Also it seems it uses "name" field and not XID. Problem with that is that I have several with the same name (not unique).</p>
<p dir="auto">Could you fix the "Add a point" dropdown list so that typing the XID would find the right point? Or some similar solution....</p>
]]></description><link>https://forum.mango-os.com/topic/2029/excel-reports-add-a-point-functionality</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Apr 2026 23:17:19 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2029.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 27 Nov 2015 08:18:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Excel Reports - Add a point functionality on Mon, 04 Jan 2016 08:33:06 GMT]]></title><description><![CDATA[<p dir="auto">Hello</p>
<p dir="auto">I have upgraded our Mango today and this issue is resolved :) Thank you very much.</p>
<p dir="auto">Today I started creating reports and noticed that it fails if some cell contains for example:<br />
<strong>=PROPER(SLA!G9)&amp;" Environmental Averages"</strong></p>
<p dir="auto">Message in the log is: Error evaluating cell 'HEL01 - Environmental Averages'!A1</p>
<p dir="auto">What's up?</p>
]]></description><link>https://forum.mango-os.com/post/10760</link><guid isPermaLink="true">https://forum.mango-os.com/post/10760</guid><dc:creator><![CDATA[sjobbe]]></dc:creator><pubDate>Mon, 04 Jan 2016 08:33:06 GMT</pubDate></item><item><title><![CDATA[Reply to Excel Reports - Add a point functionality on Sat, 19 Dec 2015 20:56:14 GMT]]></title><description><![CDATA[<p dir="auto">Hi sjobbe,</p>
<p dir="auto">We've closed the issue by implementing XID search in the next version of the module. Check for it from your modules page!</p>
]]></description><link>https://forum.mango-os.com/post/10700</link><guid isPermaLink="true">https://forum.mango-os.com/post/10700</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Sat, 19 Dec 2015 20:56:14 GMT</pubDate></item><item><title><![CDATA[Reply to Excel Reports - Add a point functionality on Fri, 27 Nov 2015 18:59:26 GMT]]></title><description><![CDATA[<p dir="auto">Thank you</p>
]]></description><link>https://forum.mango-os.com/post/10614</link><guid isPermaLink="true">https://forum.mango-os.com/post/10614</guid><dc:creator><![CDATA[sjobbe]]></dc:creator><pubDate>Fri, 27 Nov 2015 18:59:26 GMT</pubDate></item><item><title><![CDATA[Reply to Excel Reports - Add a point functionality on Fri, 27 Nov 2015 17:58:02 GMT]]></title><description><![CDATA[<p dir="auto">I filed a git issue here, you can follow it for updates: <a href="https://github.com/infiniteautomation/ma-core-public/issues/454" rel="nofollow ugc">https://github.com/infiniteautomation/ma-core-public/issues/454</a></p>
]]></description><link>https://forum.mango-os.com/post/10613</link><guid isPermaLink="true">https://forum.mango-os.com/post/10613</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Fri, 27 Nov 2015 17:58:02 GMT</pubDate></item><item><title><![CDATA[Reply to Excel Reports - Add a point functionality on Fri, 27 Nov 2015 17:54:23 GMT]]></title><description><![CDATA[<p dir="auto">I've tested this a bit more and it does seem that the Device Name search is not performing as it should.  We'll look into this and should be something we can resolve soon.  Thanks. Joel.</p>
]]></description><link>https://forum.mango-os.com/post/10612</link><guid isPermaLink="true">https://forum.mango-os.com/post/10612</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Fri, 27 Nov 2015 17:54:23 GMT</pubDate></item><item><title><![CDATA[Reply to Excel Reports - Add a point functionality on Fri, 27 Nov 2015 17:50:41 GMT]]></title><description><![CDATA[<p dir="auto">I can't get it to "search" with Device Name. If it would do that then there would not be any problem.</p>
<p dir="auto">Only typing in the "Point Name" seems to yeld results but we have named out points as your suggestion similarly (ie. KWH or L1-A etc....)</p>
]]></description><link>https://forum.mango-os.com/post/10611</link><guid isPermaLink="true">https://forum.mango-os.com/post/10611</guid><dc:creator><![CDATA[sjobbe]]></dc:creator><pubDate>Fri, 27 Nov 2015 17:50:41 GMT</pubDate></item><item><title><![CDATA[Reply to Excel Reports - Add a point functionality on Fri, 27 Nov 2015 15:18:25 GMT]]></title><description><![CDATA[<p dir="auto">The drop down box searches the Device Name and the Data Point name which is the same as the other drop down lists throughout Mango.  Could you solve this issue but using better defined Device Names or Data Point Names?  I don't think it's normal use to use XID's for this purpose.</p>
<p dir="auto">Thanks,<br />
Joel.</p>
]]></description><link>https://forum.mango-os.com/post/10610</link><guid isPermaLink="true">https://forum.mango-os.com/post/10610</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Fri, 27 Nov 2015 15:18:25 GMT</pubDate></item></channel></rss>
