<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[A server error has occurred]]></title><description><![CDATA[<p dir="auto">I often see the message 'A server error has occurred' appear in a pop-up window.<img src="https://i.imgur.com/uEGDGw0.png" alt="A server error has occurred.png" class=" img-fluid img-markdown" />  Most often it pops up when I click on a link that takes me to another Mango page, but sometimes it occurs on its own, when I have not done anything on the page. Most often I see it on a graphics page, but that's probably because that's the page I have open most often.</p>
<p dir="auto">When I check ma.log, I don't see any log entries at all around the times these errors occur. Since I'm on a slow ISP with high latency, I suspect it is a dojo timeout error, or a catch-all javascript error. Could it be caused when the socket closes? Can we please get more clarity as to the possible causes of these errors, or increase the timeout if that is the cause? Ideally, if this is a "no response received" issue, then the message should report "no response" rather than blaming the server.</p>
<p dir="auto">I often get  on the data_point_edit.shtm page and the events.shtm page, but that is not in a pop-up window, and looks quite different:<img src="https://i.imgur.com/7A5200y.png" alt="Server error Timeout.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Thanks for your help.</p>
]]></description><link>https://forum.mango-os.com/topic/2016/a-server-error-has-occurred</link><generator>RSS for Node</generator><lastBuildDate>Thu, 05 Mar 2026 08:52:33 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2016.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 05 Nov 2015 00:18:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to A server error has occurred on Mon, 09 Nov 2015 20:33:07 GMT]]></title><description><![CDATA[<p dir="auto">Which error do you get a lot? the Timeout error? Does it make a difference if the alarms are acknowledged, or do they have to be purged?</p>
<p dir="auto">Do you ever get the 'A server error has occurred' pop-up dialog?</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://forum.mango-os.com/post/10538</link><guid isPermaLink="true">https://forum.mango-os.com/post/10538</guid><dc:creator><![CDATA[Pedro]]></dc:creator><pubDate>Mon, 09 Nov 2015 20:33:07 GMT</pubDate></item><item><title><![CDATA[Reply to A server error has occurred on Thu, 05 Nov 2015 08:25:00 GMT]]></title><description><![CDATA[<p dir="auto">I get this error a lot when a system has generated a large number of alarms (thousands). Purging the alarms stops the error. You can delete all the events at once by entering:</p>
<pre><code>delete from events
<p dir="auto">in the SQL console.</p>
]]></description><link>https://forum.mango-os.com/post/10537</link><guid isPermaLink="true">https://forum.mango-os.com/post/10537</guid><dc:creator><![CDATA[jeremyh]]></dc:creator><pubDate>Thu, 05 Nov 2015 08:25:00 GMT</pubDate></item></channel></rss>
