<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[V2.6 Quantize]]></title><description><![CDATA[<p dir="auto">does v2.6 not have a quantize logging option for the interval logging type?</p>
]]></description><link>https://forum.mango-os.com/topic/1974/v2-6-quantize</link><generator>RSS for Node</generator><lastBuildDate>Mon, 18 May 2026 01:09:12 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/1974.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 11 Sep 2015 13:23:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to V2.6 Quantize on Wed, 23 Sep 2015 14:00:39 GMT]]></title><description><![CDATA[<p dir="auto">I am sure the Quantize  checkbox  is useful in modbus, my logging type is ON_CHANGE, please test in ON_CHANGE condition</p>
]]></description><link>https://forum.mango-os.com/post/10388</link><guid isPermaLink="true">https://forum.mango-os.com/post/10388</guid><dc:creator><![CDATA[hussam]]></dc:creator><pubDate>Wed, 23 Sep 2015 14:00:39 GMT</pubDate></item><item><title><![CDATA[Reply to V2.6 Quantize on Thu, 17 Sep 2015 17:19:06 GMT]]></title><description><![CDATA[<p dir="auto">Thanks, this is really useful.  Terry and I talked about this yesterday and we'll see if there are some easy solutions to include in the 2.6 release.</p>
<p dir="auto">Thanks,</p>
]]></description><link>https://forum.mango-os.com/post/10374</link><guid isPermaLink="true">https://forum.mango-os.com/post/10374</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Thu, 17 Sep 2015 17:19:06 GMT</pubDate></item><item><title><![CDATA[Reply to V2.6 Quantize on Thu, 17 Sep 2015 17:17:50 GMT]]></title><description><![CDATA[<p dir="auto">Here is the info. Would be out by 6min 40sec</p>
<p dir="auto"><img src="https://camo.nodebb.org/dfae8feb1df01fd9ce4ba58426d9f0621d7ef285?url=https%3A%2F%2Fi.imgur.com%2FIVNDAhs.png" alt="Datasource.PNG" class=" img-fluid img-markdown" /> <img src="https://camo.nodebb.org/4aa5fdf7d72c68449cedfe4121d7e11879bf6882?url=https%3A%2F%2Fi.imgur.com%2FIhaqh0M.png" alt="point.PNG" class=" img-fluid img-markdown" /> <a href="/forum/uploads/files/1442510200082-pointdata-2015-09-17_19-12-55.xlsx">pointData-2015-09-17_19-12-55.xlsx</a></p>
]]></description><link>https://forum.mango-os.com/post/10373</link><guid isPermaLink="true">https://forum.mango-os.com/post/10373</guid><dc:creator><![CDATA[alexcclarke]]></dc:creator><pubDate>Thu, 17 Sep 2015 17:17:50 GMT</pubDate></item><item><title><![CDATA[Reply to V2.6 Quantize on Thu, 17 Sep 2015 14:53:25 GMT]]></title><description><![CDATA[<p dir="auto">What are your logging settings for the data points?   Also can you post an csv export of one of the data points.  I'm curious to see how far off the logged time stamps are.  Is it just a few milliseconds?</p>
]]></description><link>https://forum.mango-os.com/post/10372</link><guid isPermaLink="true">https://forum.mango-os.com/post/10372</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Thu, 17 Sep 2015 14:53:25 GMT</pubDate></item><item><title><![CDATA[Reply to V2.6 Quantize on Thu, 17 Sep 2015 11:43:17 GMT]]></title><description><![CDATA[<p dir="auto">I have the modbus data source Quantize check box checked, this only has an effect on the data update period.  However the logging is not Quantize and there is no check box to enable this when I enable the logging of a point.</p>
]]></description><link>https://forum.mango-os.com/post/10371</link><guid isPermaLink="true">https://forum.mango-os.com/post/10371</guid><dc:creator><![CDATA[alexcclarke]]></dc:creator><pubDate>Thu, 17 Sep 2015 11:43:17 GMT</pubDate></item><item><title><![CDATA[Reply to V2.6 Quantize on Wed, 16 Sep 2015 13:58:40 GMT]]></title><description><![CDATA[<p dir="auto">In 2.6 as will all other versions there is still the option to Quantize the polls for Modbus data sources.  I think Modbus is the only data source that has this.  Data will still be logged based on when it is received so the actual logged value may still be off by some milliseconds.</p>
<p dir="auto">Try this out and let us know if it will be sufficient for you.</p>
]]></description><link>https://forum.mango-os.com/post/10367</link><guid isPermaLink="true">https://forum.mango-os.com/post/10367</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Wed, 16 Sep 2015 13:58:40 GMT</pubDate></item><item><title><![CDATA[Reply to V2.6 Quantize on Wed, 16 Sep 2015 13:02:07 GMT]]></title><description><![CDATA[<p dir="auto">Hi Terry, it is vital for the applications that I am using Mango for that the logging is exactly on the hour.  For example for billing purposes this is important.  Are you sure this was not a feature for modbus in older versions?  Can it be added as a feature?</p>
]]></description><link>https://forum.mango-os.com/post/10366</link><guid isPermaLink="true">https://forum.mango-os.com/post/10366</guid><dc:creator><![CDATA[alexcclarke]]></dc:creator><pubDate>Wed, 16 Sep 2015 13:02:07 GMT</pubDate></item><item><title><![CDATA[Reply to V2.6 Quantize on Sat, 12 Sep 2015 16:11:26 GMT]]></title><description><![CDATA[<p dir="auto">This is a Alternate Method,you can set a datasource's cron string  replace interval logging type,you can Define a Quantize  cron yourself.</p>
]]></description><link>https://forum.mango-os.com/post/10352</link><guid isPermaLink="true">https://forum.mango-os.com/post/10352</guid><dc:creator><![CDATA[hussam]]></dc:creator><pubDate>Sat, 12 Sep 2015 16:11:26 GMT</pubDate></item><item><title><![CDATA[Reply to V2.6 Quantize on Fri, 11 Sep 2015 23:41:21 GMT]]></title><description><![CDATA[<p dir="auto">Quantization can only be set on some datasources in their polling configuration.  Unless I'm mistaken Mango has never had the ability to Quantize Logging in the data point configuration.</p>
]]></description><link>https://forum.mango-os.com/post/10349</link><guid isPermaLink="true">https://forum.mango-os.com/post/10349</guid><dc:creator><![CDATA[terrypacker]]></dc:creator><pubDate>Fri, 11 Sep 2015 23:41:21 GMT</pubDate></item></channel></rss>
