<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[BACnet IP discovery not working on linux]]></title><description><![CDATA[<p dir="auto">Hi every one,<br />
I have trouble with BACnet IP discovery on linux. But Bacnet data point can read data from devices when i using manual creating point. When i install mango on windown it works. I have updated to jdk 8 but can not issue. How can i fit?<br />
Thanks,<br />
Thien</p>
]]></description><link>https://forum.mango-os.com/topic/1922/bacnet-ip-discovery-not-working-on-linux</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Apr 2026 09:23:44 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/1922.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 17 Jul 2015 15:14:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to BACnet IP discovery not working on linux on Mon, 27 Jul 2015 15:15:02 GMT]]></title><description><![CDATA[<p dir="auto">Hard to say what is going on but it sounds like a networking issue.  Are all the devices on the same subnet?</p>
<p dir="auto">You can check on the system setting under the BACnet local device options and try some different configurations there with the local binding address.</p>
]]></description><link>https://forum.mango-os.com/post/10154</link><guid isPermaLink="true">https://forum.mango-os.com/post/10154</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Mon, 27 Jul 2015 15:15:02 GMT</pubDate></item><item><title><![CDATA[Reply to BACnet IP discovery not working on linux on Fri, 24 Jul 2015 08:39:13 GMT]]></title><description><![CDATA[<p dir="auto">I have try install BACnet 2.1.3 and various java version but it not working.<br />
Thanks,</p>
]]></description><link>https://forum.mango-os.com/post/10144</link><guid isPermaLink="true">https://forum.mango-os.com/post/10144</guid><dc:creator><![CDATA[ThienTran]]></dc:creator><pubDate>Fri, 24 Jul 2015 08:39:13 GMT</pubDate></item><item><title><![CDATA[Reply to BACnet IP discovery not working on linux on Sat, 18 Jul 2015 16:34:48 GMT]]></title><description><![CDATA[<p dir="auto">You are using the beta version of BACnet.  Can you try version 2.1.3 and let me know if there is any difference?  <a href="http://store.infiniteautomation.com/module/BACnet" rel="nofollow ugc">http://store.infiniteautomation.com/module/BACnet</a></p>
<p dir="auto">Thanks,</p>
]]></description><link>https://forum.mango-os.com/post/10131</link><guid isPermaLink="true">https://forum.mango-os.com/post/10131</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Sat, 18 Jul 2015 16:34:48 GMT</pubDate></item><item><title><![CDATA[Reply to BACnet IP discovery not working on linux on Sat, 18 Jul 2015 15:51:12 GMT]]></title><description><![CDATA[<p dir="auto">Hi Joel,<br />
I have just install java 7u80 but can not resolve. Core version 2.5.2 and bacnet is 2.1.5.<br />
Thanks</p>
]]></description><link>https://forum.mango-os.com/post/10130</link><guid isPermaLink="true">https://forum.mango-os.com/post/10130</guid><dc:creator><![CDATA[ThienTran]]></dc:creator><pubDate>Sat, 18 Jul 2015 15:51:12 GMT</pubDate></item><item><title><![CDATA[Reply to BACnet IP discovery not working on linux on Sat, 18 Jul 2015 00:59:58 GMT]]></title><description><![CDATA[<p dir="auto">Hi Joel,<br />
I have updated latest core and bacnet and java 8. i will try to install java7.<br />
thanks</p>
]]></description><link>https://forum.mango-os.com/post/10129</link><guid isPermaLink="true">https://forum.mango-os.com/post/10129</guid><dc:creator><![CDATA[ThienTran]]></dc:creator><pubDate>Sat, 18 Jul 2015 00:59:58 GMT</pubDate></item><item><title><![CDATA[Reply to BACnet IP discovery not working on linux on Fri, 17 Jul 2015 22:47:23 GMT]]></title><description><![CDATA[<p dir="auto">It's generally recommended to use Java 7 which is what Mango is compiled against. I'd be surprised if that was your issue but I don't have enough information to go on.  What version of Mango Core and BACnet module?  Do you see any errors in your log files?</p>
]]></description><link>https://forum.mango-os.com/post/10128</link><guid isPermaLink="true">https://forum.mango-os.com/post/10128</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Fri, 17 Jul 2015 22:47:23 GMT</pubDate></item></channel></rss>
