<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Nullpointer in vmstat when exiting]]></title><description><![CDATA[<p dir="auto">Whenever I shutdown mango the vmstat daemon thread crashes with a nullpointer exception.  this isn't a big deal since I am shutting it down anyway, but it also happens when disabling the data source:</p>
<p dir="auto">stack:</p>
<pre><code>this	VMStatDataSourceRT  (id=189)
	addedChangedPoints	ArrayList&lt;E&gt;  (id=200)
		elementData	Object[10]  (id=233)
		modCount	0
		size	0
	attributePositions	HashMap&lt;K,V&gt;  (id=210)
		entrySet	HashMap$EntrySet  (id=309)
		keySet	null
		loadFactor	0.75
		modCount	16
		size	16
		table	HashMap$Entry&lt;K,V&gt;[32]  (id=311)
		threshold	24
		values	null
	dataPoints	ArrayList&lt;E&gt;  (id=214)
		elementData	Object[10]  (id=308)
		modCount	0
		size	0
	eventTypes	ArrayList&lt;E&gt;  (id=215)
		elementData	Object[10]  (id=307)
		modCount	2
		size	2
	in	BufferedReader  (id=216)
		cb	 (id=303)
		in	InputStreamReader  (id=305)
		lock	InputStreamReader  (id=305)
		markedChar	-1
		markedSkipLF	false
		nChars	78
		nextChar	78
		readAheadLimit	0
		skipBuffer	null
		skipLF	false
	log	Log4JLogger  (id=221)
		logger	Logger  (id=298)
		name	"com.serotonin.mango.rt.dataSource.vmstat.VMStatDataSourceRT" (id=302)
	pointListChangeLock	Boolean  (id=224)
		value	false
	removedPoints	ArrayList&lt;E&gt;  (id=227)
		elementData	Object[10]  (id=297)
		modCount	0
		size	0
	terminated	true
	vmstatProcess	UNIXProcess  (id=194)
		exitcode	143
		hasExited	true
		pid	18998
		stderr_fd	FileDescriptor  (id=286)
		stderr_stream	FileInputStream  (id=288)
		stdin_fd	FileDescriptor  (id=291)
		stdin_stream	BufferedOutputStream  (id=292)
		stdout_fd	FileDescriptor  (id=312)
		stdout_stream	BufferedInputStream  (id=313)
	vo	VMStatDataSourceVO  (id=228)
		alarmLevels	HashMap&lt;K,V&gt;  (id=274)
		enabled	true
		id	6
		name	"vmstat" (id=282)
		outputScale	2
		pollSeconds	60
		xid	"DS_742792" (id=285)
			entrySet	HashMap$EntrySet  (id=275)
			keySet	null
			loadFactor	0.75
			modCount	2
			size	2
			table	HashMap$Entry&lt;K,V&gt;[16]  (id=279)
			threshold	12
			values	null
		enabled	true
		id	6
		outputScale	2
		pollSeconds	60
line	null
<p dir="auto">As you can see line is null. the nullpointer occurs at the readParts(line.split) line below, every time when I shut down.</p>
<pre><code> public void run() {
        try {
            while (true) {
                String line = in.readLine();
                readParts(line.split("\\s+"));
                readError();
<p dir="auto">The appropriate fix isn't obvious to me.</p>
]]></description><link>https://forum.mango-os.com/topic/191/nullpointer-in-vmstat-when-exiting</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Apr 2026 23:27:38 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/191.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 20 Sep 2009 21:36:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Nullpointer in vmstat when exiting on Mon, 21 Sep 2009 14:24:34 GMT]]></title><description><![CDATA[<p dir="auto">Hi Craig,</p>
<p dir="auto">I already have a fix for this in for the next version. I did this:</p>
<pre><code>
            while (true) {
                if (line == null) {
                    if (terminated)
                        break;
                    else
                        throw new IOException("no data");
                readError();
]]></description><link>https://forum.mango-os.com/post/2700</link><guid isPermaLink="true">https://forum.mango-os.com/post/2700</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Mon, 21 Sep 2009 14:24:34 GMT</pubDate></item></channel></rss>
