<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Setting Timezone]]></title><description><![CDATA[<p dir="auto">What is the best way to set the timezone on the MangoES?</p>
<p dir="auto">Should I simply log in with SSH and run:</p>
<pre><code>dpkg-reconfigure tzdata
<p dir="auto">Thanks<br />
Jeremy</p>
]]></description><link>https://forum.mango-os.com/topic/1904/setting-timezone</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 22:30:42 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/1904.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 22 Jun 2015 03:00:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Setting Timezone on Tue, 23 Jun 2015 05:44:17 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Joel, setting the timezone through Webmin worked fine.</p>
]]></description><link>https://forum.mango-os.com/post/10086</link><guid isPermaLink="true">https://forum.mango-os.com/post/10086</guid><dc:creator><![CDATA[jeremyh]]></dc:creator><pubDate>Tue, 23 Jun 2015 05:44:17 GMT</pubDate></item><item><title><![CDATA[Reply to Setting Timezone on Mon, 22 Jun 2015 03:12:50 GMT]]></title><description><![CDATA[<p dir="auto">If you are running Mango 2.5 or higher you can use the MangoES Configuration module: <a href="http://store.infiniteautomation.com/module/mangoESConfiguration" rel="nofollow ugc">http://store.infiniteautomation.com/module/mangoESConfiguration</a>  To install it go to the Modules page in your Mango and click "Check for updates" and then select "Modules available for install"</p>
<p dir="auto">It shows up as a category on the system setting page and allows you to select the time zone and set IP addresses.  Note that it will require a reboot of Mango to get the new time zone settings.</p>
<p dir="auto">You can also set the time zone through ssh or webmin: <a href="http://infiniteautomation.com/wiki/doku.php?id=mangoes:gettingstarted#accessing_the_os_through_webmin" rel="nofollow ugc">http://infiniteautomation.com/wiki/doku.php?id=mangoes:gettingstarted#accessing_the_os_through_webmin</a></p>
]]></description><link>https://forum.mango-os.com/post/10082</link><guid isPermaLink="true">https://forum.mango-os.com/post/10082</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Mon, 22 Jun 2015 03:12:50 GMT</pubDate></item></channel></rss>
