<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Custom CSS overrides]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">It would be really nice if the mango admin user could simply add some CSS overrides to Mango's web interface. A simple text form in the mango settings page would be the most convenient.</p>
<p dir="auto">There are probably some other ways to do this such as looking for a stylesheet named "custom.css" (or similar) within the /classes/overrides folder, and loading that into the page if it exists.</p>
<p dir="auto">In any case, the end goal is simply to enable the admin user to make some minor css adjustments without having to re-do them after upgrades.</p>
<p dir="auto">Thanks!</p>
<p dir="auto">Thanks,<br />
Jeremy</p>
]]></description><link>https://forum.mango-os.com/topic/1898/custom-css-overrides</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Apr 2026 21:18:21 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/1898.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 31 May 2015 02:29:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Custom CSS overrides on Mon, 01 Jun 2015 16:23:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joelhaggar" aria-label="Profile: JoelHaggar">@<bdi>JoelHaggar</bdi></a> said:</p>
<p dir="auto">The other method is to you a theme module like this one and modify it's contents: <a href="http://store.infiniteautomation.com/module/sstTheme" rel="nofollow ugc">http://store.infiniteautomation.com/module/sstTheme</a></p>
<p dir="auto">Hi Joel,</p>
<p dir="auto">As it happened that's what I had been doing. The theme was installed by default and that's where I found the classes that I wanted to modify.</p>
<p dir="auto">If I continue editing the file <em>web/modules/sstTheme/web/style.css</em>, will this get overwritten during an upgrade (either manual or via APT) or is this safe?</p>
<p dir="auto">I have made some minor cosmetic changes just to my own taste and to freshen it. If anyone would like to, you can download the edited file here: <a href="/uploads/files/1433175676353-style.css">style.css</a>  (Overwrite it in the path above)</p>
<p dir="auto">My changes:</p>
<p dir="auto"><img src="https://camo.nodebb.org/167c563f9542845dfab02c24c337f79260bffbdd?url=https%3A%2F%2Fi.imgur.com%2FCa0TuMI.png" alt="Screen Shot 2015-06-02 at 12.14.44 am.png" class=" img-fluid img-markdown" /><br />
<img src="https://camo.nodebb.org/15498788189bef5624c13f911a0428145af6879b?url=https%3A%2F%2Fi.imgur.com%2FCGISgwB.png" alt="Screen Shot 2015-06-02 at 12.15.02 am.png" class=" img-fluid img-markdown" /> <img src="https://camo.nodebb.org/9ce99bf531b05fda7cbe2ead377a2caffd73fa70?url=https%3A%2F%2Fi.imgur.com%2F84Ypfc6.png" alt="Screen Shot 2015-06-02 at 12.15.24 am.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/10058</link><guid isPermaLink="true">https://forum.mango-os.com/post/10058</guid><dc:creator><![CDATA[jeremyh]]></dc:creator><pubDate>Mon, 01 Jun 2015 16:23:50 GMT</pubDate></item><item><title><![CDATA[Reply to Custom CSS overrides on Mon, 01 Jun 2015 03:17:02 GMT]]></title><description><![CDATA[<p dir="auto">I'm pretty sure we already have this feature with two methods.  As you suggest you should be able to put the css you want to use in the overrides folder under the same path as the original file.</p>
]]></description><link>https://forum.mango-os.com/post/10057</link><guid isPermaLink="true">https://forum.mango-os.com/post/10057</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Mon, 01 Jun 2015 03:17:02 GMT</pubDate></item></channel></rss>
