<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Reading a UDP device using the TCPIP datasource module]]></title><description><![CDATA[<p dir="auto">Does the TCPIP datasource module support reading UDP devices? If not, what alternatives are there for reading UDP, short of writing a custom module?</p>
]]></description><link>https://forum.mango-os.com/topic/1875/reading-a-udp-device-using-the-tcpip-datasource-module</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 13:07:56 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/1875.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 01 May 2015 21:12:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Reading a UDP device using the TCPIP datasource module on Thu, 14 May 2015 15:12:18 GMT]]></title><description><![CDATA[<p dir="auto">Thanks, Terry. I was thinking that duplicating the TCPIP data source would be a good start and save a lot of work. Another option is to simply add a UDP checkbox to the TCPIP source, though that may require renaming the source to "IP."</p>
]]></description><link>https://forum.mango-os.com/post/9993</link><guid isPermaLink="true">https://forum.mango-os.com/post/9993</guid><dc:creator><![CDATA[Pedro]]></dc:creator><pubDate>Thu, 14 May 2015 15:12:18 GMT</pubDate></item><item><title><![CDATA[Reply to Reading a UDP device using the TCPIP datasource module on Sat, 02 May 2015 21:28:53 GMT]]></title><description><![CDATA[<p dir="auto">Pedro,</p>
<p dir="auto">It currently doesn't support UDP and I'm not aware of any module that does.  I've written some UDP code in Java before and I don't think it would be too much work to add UDP support to the module.   I'll put it on the list for the future but if you want it sooner I would contact JoelHaggar.</p>
]]></description><link>https://forum.mango-os.com/post/9965</link><guid isPermaLink="true">https://forum.mango-os.com/post/9965</guid><dc:creator><![CDATA[terrypacker]]></dc:creator><pubDate>Sat, 02 May 2015 21:28:53 GMT</pubDate></item></channel></rss>
