<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MangoES Network Discovery Tool]]></title><description><![CDATA[<p dir="auto">If you have the <a href="http://store.infiniteautomation.com/module/mangoESConfiguration" rel="nofollow ugc">MangoES Configuration Module</a> version 1.0.3 or newer installed you can use this network discovery tool to find the IP address of a MangoES connected to your network.</p>
<p dir="auto"><a href="http://infiniteautomation.com/wiki/doku.php?id=mangoes:discoverytool" rel="nofollow ugc">Download MangoES Discovery 1.0.0.zip</a></p>
<p dir="auto">Once downloaded unzip the file and double click on the mangoES-Discovery-1.0.0.jar file. You will get a window popup that will display any found MangoES's on your network.</p>
<p dir="auto"><iframe class="vimeo-embed" src="//player.vimeo.com/video/124059442" width="640" height="360" frameborder="0"></iframe></p>
]]></description><link>https://forum.mango-os.com/topic/1846/mangoes-network-discovery-tool</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Apr 2026 20:32:37 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/1846.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 03 Apr 2015 20:40:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MangoES Network Discovery Tool on Mon, 27 Apr 2015 19:03:58 GMT]]></title><description><![CDATA[<p dir="auto">I have confirmed that the discovery tool will find the MangoES and tell you what it's IP is even if it's on a different IP range.  For example my MangoES has a static Ip of 10.0.0.185 and it's plugged into my network which is 192.168.1.X.  Running the discover tool will find and display the MangoES's IP which is really handy.</p>
]]></description><link>https://forum.mango-os.com/post/9954</link><guid isPermaLink="true">https://forum.mango-os.com/post/9954</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Mon, 27 Apr 2015 19:03:58 GMT</pubDate></item><item><title><![CDATA[Reply to MangoES Network Discovery Tool on Tue, 07 Apr 2015 02:56:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jeremyh" aria-label="Profile: jeremyh">@<bdi>jeremyh</bdi></a> That's a really good question and I have not tested it but will let you know.  It might as it uses Bonjour to broadcast the network information.  It's a nice idea to be able to configure it as well and maybe once the Mango API is more flushed out that could be a possibility.</p>
]]></description><link>https://forum.mango-os.com/post/9855</link><guid isPermaLink="true">https://forum.mango-os.com/post/9855</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Tue, 07 Apr 2015 02:56:42 GMT</pubDate></item><item><title><![CDATA[Reply to MangoES Network Discovery Tool on Tue, 07 Apr 2015 02:48:03 GMT]]></title><description><![CDATA[<p dir="auto">Fantastic!</p>
<p dir="auto">Will this tool show the MangoES even if it does not have an IP address or is set to a different network?</p>
<p dir="auto">It would be great to also be able to set the IP address configuration using this tool (using layer 2) but I don't know how technically feasible this is.</p>
]]></description><link>https://forum.mango-os.com/post/9854</link><guid isPermaLink="true">https://forum.mango-os.com/post/9854</guid><dc:creator><![CDATA[jeremyh]]></dc:creator><pubDate>Tue, 07 Apr 2015 02:48:03 GMT</pubDate></item></channel></rss>
