<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to Calculate kWh from kW]]></title><description><![CDATA[<p dir="auto">Here is a post in our wiki for a Meta Data Script to calculate kWh from a kW reading.  It's not going to be as accurate as an actual kWh meter but sometimes all you have is kW.</p>
<p dir="auto"><a href="http://infiniteautomation.com/wiki/doku.php?id=automation:script_examples" rel="nofollow ugc">http://infiniteautomation.com/wiki/doku.php?id=automation:script_examples</a></p>
<pre><code>var lastKw = p1.lastValue(1);
var nowKw = p1.lastValue(0);
var period = nowKw.time - lastKw.time;
var kWlast = lastKw.value;
return kWlast /  (3600000/period);
]]></description><link>https://forum.mango-os.com/topic/1834/how-to-calculate-kwh-from-kw</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 04:02:27 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/1834.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 18 Mar 2015 21:29:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to Calculate kWh from kW on Sat, 25 Feb 2023 09:17:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nino-kurtalj" aria-label="Profile: nino-kurtalj">@<bdi>nino-kurtalj</bdi></a> New link is here: <a href="https://docs-v4.radixiot.com/script-examples" rel="nofollow ugc">https://docs-v4.radixiot.com/script-examples</a></p>
]]></description><link>https://forum.mango-os.com/post/27727</link><guid isPermaLink="true">https://forum.mango-os.com/post/27727</guid><dc:creator><![CDATA[tungthanh500]]></dc:creator><pubDate>Sat, 25 Feb 2023 09:17:58 GMT</pubDate></item><item><title><![CDATA[Reply to How to Calculate kWh from kW on Fri, 24 Feb 2023 10:55:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joelhaggar" aria-label="Profile: JoelHaggar">@<bdi>JoelHaggar</bdi></a><br />
the link is not working any more</p>
]]></description><link>https://forum.mango-os.com/post/27722</link><guid isPermaLink="true">https://forum.mango-os.com/post/27722</guid><dc:creator><![CDATA[nino kurtalj]]></dc:creator><pubDate>Fri, 24 Feb 2023 10:55:09 GMT</pubDate></item></channel></rss>
