<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Trouble running test program]]></title><description><![CDATA[<p dir="auto">Hello, all,</p>
<p dir="auto">I downloaded test program from BACNet4J.  I tried to setup using Eclipse IDE with all source code and .jar file.  But getting these errors and exception when running.  Something simple wrong in setup?  any ideas?</p>
<p dir="auto">really appreciate it, thanks</p>
<p dir="auto">Description	Resource	Path	Location	Type<br />
Bound mismatch: The generic method readSequenceOf(ByteQueue, Class&lt;T&gt;, int) of type Encodable is not applicable for the arguments (ByteQueue, Class&lt;capture#3-of ? extends Encodable&gt;, int). The inferred type capture#3-of ? extends Encodable is not a valid substitute for the bounded parameter &lt;T extends Encodable&gt;	Encodable.java	BACNet test/src/bacnet4j/type	line 261	Java Problem</p>
<p dir="auto">Exception in thread "main" java.lang.Error: Unresolved compilation problem:</p>
<pre><code>at bacnet4j.test.Test.main(Test.java:67)
]]></description><link>https://forum.mango-os.com/topic/172/trouble-running-test-program</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 19:52:11 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/172.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 06 Jun 2009 02:33:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Trouble running test program on Mon, 08 Jun 2009 13:53:47 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">The source code in CVS currently represents a later version than what is in the archive. To use test code from CVS you need to get the implementation code from CVS and build it into a jar file yourself. The build scripts are in CVS too.</p>
]]></description><link>https://forum.mango-os.com/post/2606</link><guid isPermaLink="true">https://forum.mango-os.com/post/2606</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Mon, 08 Jun 2009 13:53:47 GMT</pubDate></item></channel></rss>
