<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Suggestion - Don]]></title><description><![CDATA[<p dir="auto">Hi</p>
<p dir="auto">When Mango is set to 'log point changes only' it becomes problematic when a value goes to zero, stays there, and then changes again:</p>
<p dir="auto"><img src="https://camo.nodebb.org/362c4f4829b2866bab16c9a66a3c3fc512fe6fa8?url=http%3A%2F%2Fcl.ly%2Fimage%2F161z0S0E3Z1i%2FScreen%2520Shot%25202014-09-10%2520at%25202.17.24%2520pm.png" alt="image" class=" img-fluid img-markdown" /></p>
<p dir="auto">In this example, the value changed to 0 at time A, then <em>remained</em> at 0 until a new value was recorded at time B.<br />
This gives quite an ugly and perhaps misleading chart rendering. The only other option is to set Mango to 'log all data', but this - i assume - consumes DB space.</p>
<p dir="auto">It would be nice if there were some workaround in Mango for this. Something like 'discard intermediate values and record first and last values for repeating values'.</p>
<p dir="auto">Or maybe there's a workaround that someone can suggest?</p>
]]></description><link>https://forum.mango-os.com/topic/1695/suggestion-don</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Apr 2026 11:41:22 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/1695.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 10 Sep 2014 10:30:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Suggestion - Don on Sat, 13 Sep 2014 01:38:59 GMT]]></title><description><![CDATA[<p dir="auto">This is an interesting problem but it's probably more of an issue with how the Chart interprets the data something we can definitely look at.  Thanks.</p>
]]></description><link>https://forum.mango-os.com/post/9231</link><guid isPermaLink="true">https://forum.mango-os.com/post/9231</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Sat, 13 Sep 2014 01:38:59 GMT</pubDate></item><item><title><![CDATA[Reply to Suggestion - Don on Fri, 12 Sep 2014 09:34:06 GMT]]></title><description><![CDATA[<p dir="auto">Am i understanded right? int fact,between time A and time B,have many points which values is  0,but they don't be store because they don't change. this is the logging rule,but we have one solution at query pointvalues from database,we can set up one interval option at query.</p>
<p dir="auto">for example,between tim A and time B,assume have 60 seconds ,if the query interval is 2 second,we will get 30 pointvalues,we will copy the time A 'value 0 to 30times, until to time B, then we can restore really situation.</p>
]]></description><link>https://forum.mango-os.com/post/9225</link><guid isPermaLink="true">https://forum.mango-os.com/post/9225</guid><dc:creator><![CDATA[hussam]]></dc:creator><pubDate>Fri, 12 Sep 2014 09:34:06 GMT</pubDate></item><item><title><![CDATA[Reply to Suggestion - Don on Fri, 12 Sep 2014 06:13:46 GMT]]></title><description><![CDATA[<p dir="auto">I had this too. I gave up on trying to fix this. I just set it to "interval" 1 min. For some reason I don't get zeros any more.</p>
]]></description><link>https://forum.mango-os.com/post/9223</link><guid isPermaLink="true">https://forum.mango-os.com/post/9223</guid><dc:creator><![CDATA[Balistar]]></dc:creator><pubDate>Fri, 12 Sep 2014 06:13:46 GMT</pubDate></item></channel></rss>
