<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How long  when use derby database for store data that the mango connect equipment?]]></title><description><![CDATA[<p dir="auto">If I choose the derby database ,how long how long  when use derby database for store data that the mango connect equipment? if I choose mysql or postpresql, how to setting in mango in windows version.</p>
]]></description><link>https://forum.mango-os.com/topic/1612/how-long-when-use-derby-database-for-store-data-that-the-mango-connect-equipment</link><generator>RSS for Node</generator><lastBuildDate>Mon, 08 Jun 2026 05:54:10 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/1612.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 28 Jul 2014 16:15:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How long  when use derby database for store data that the mango connect equipment? on Mon, 01 Sep 2014 05:22:41 GMT]]></title><description><![CDATA[<p dir="auto">Yes .Thank JoelHaggars.</p>
<p dir="auto">You are right. When I use bleow command .the covert db is ok.</p>
<p dir="auto">grant all privileges on  db.* To 'username'@'localhost' identified by  'password';</p>
]]></description><link>https://forum.mango-os.com/post/9188</link><guid isPermaLink="true">https://forum.mango-os.com/post/9188</guid><dc:creator><![CDATA[edmond]]></dc:creator><pubDate>Mon, 01 Sep 2014 05:22:41 GMT</pubDate></item><item><title><![CDATA[Reply to How long  when use derby database for store data that the mango connect equipment? on Mon, 28 Jul 2014 20:30:19 GMT]]></title><description><![CDATA[<p dir="auto">PostgresSQL is not an option for Mango.  To configure mango for MySQL you do that in the /classes/env.properties file.</p>
<p dir="auto">You need to create a blank database and user with full permissions to the database.</p>
]]></description><link>https://forum.mango-os.com/post/8864</link><guid isPermaLink="true">https://forum.mango-os.com/post/8864</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Mon, 28 Jul 2014 20:30:19 GMT</pubDate></item><item><title><![CDATA[Reply to How long  when use derby database for store data that the mango connect equipment? on Mon, 28 Jul 2014 20:17:51 GMT]]></title><description><![CDATA[<p dir="auto">Hi Joel:</p>
<p dir="auto">if I choose mysql or postpresql, how to setting  mango in windows version. have any step by step?</p>
]]></description><link>https://forum.mango-os.com/post/8863</link><guid isPermaLink="true">https://forum.mango-os.com/post/8863</guid><dc:creator><![CDATA[edmond]]></dc:creator><pubDate>Mon, 28 Jul 2014 20:17:51 GMT</pubDate></item><item><title><![CDATA[Reply to How long  when use derby database for store data that the mango connect equipment? on Mon, 28 Jul 2014 19:39:02 GMT]]></title><description><![CDATA[<p dir="auto">Hi Edmond,</p>
<p dir="auto">I don't really understand your question but I think I know what you are getting at and there is no set rule about how large to let a derby database get.  It should be noted that the default database being used in Mango 2.4.2 is H2 which is much better than derby.  I would say if your database is going to larger than a few GB then I would recommend going to MySQL.  In general for most production implementations of Mango I would recomend using MySQL over derby.</p>
<p dir="auto">Hope that helps.<br />
Joel.</p>
]]></description><link>https://forum.mango-os.com/post/8862</link><guid isPermaLink="true">https://forum.mango-os.com/post/8862</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Mon, 28 Jul 2014 19:39:02 GMT</pubDate></item></channel></rss>
