<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problem running &quot;mango automation&quot;]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I have a little problem, I was using "mango automation" and the program unexpectedly stopped working, the application had been closed. I tried to run it again and I have not succeeded, the application is not running.</p>
<p dir="auto">What I can do?</p>
<p dir="auto">Best Regards</p>
]]></description><link>https://forum.mango-os.com/topic/1588/problem-running-mango-automation</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Apr 2026 22:18:38 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/1588.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 14 Jul 2014 21:14:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problem running &quot;mango automation&quot; on Mon, 14 Jul 2014 22:39:39 GMT]]></title><description><![CDATA[<p dir="auto">take a look in the /logs.ma.log file and see if there is any errors or post the logs here.</p>
<p dir="auto">Try running the start up scripts from the command line and see if you see an error?  What OS are you running on?</p>
<p dir="auto">If you are double clicking on the script it may popup and then disappear in which case you miss the error.  Rather open the terminal window and run the scrip in the terminal and you will then see the error.</p>
]]></description><link>https://forum.mango-os.com/post/8766</link><guid isPermaLink="true">https://forum.mango-os.com/post/8766</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Mon, 14 Jul 2014 22:39:39 GMT</pubDate></item></channel></rss>
