<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Compound event detectors button ?]]></title><description><![CDATA[<p dir="auto">Hi, I have just installed mango automation because I want to move from ScadaBR to mango automation payed license:</p>
<p dir="auto">m2m2-core-2.1.3.zip</p>
<p dir="auto">And some modules:</p>
<p dir="auto">m2m2-maintenanceEvents-1.4.1.zip<br />
m2m2-sqlConsole-1.4.1.zip<br />
m2m2-dglux-1.0.4.zip<br />
m2m2-meta-1.4.1.zip<br />
m2m2-sqlds-1.5.0.zip<br />
m2m2-graphicalViews-1.4.3.zip<br />
m2m2-reports-2.0.2.zip<br />
m2m2-sstTheme-1.0.2.zip<br />
m2m2-scheduledEvents-1.4.1.zip<br />
m2m2-virtualDS-1.4.1.zip<br />
m2m2-internal-1.4.1.zip<br />
m2m2-scripting-1.0.1.zip<br />
m2m2-watchlists-1.5.1.zip</p>
<p dir="auto">But I can't find neither "Compound Events" and "scripts" button ..... Do they exist ? If yes, how can I get them back ? if not, how can I define compound events and write scripts ?</p>
<p dir="auto">Best regards.</p>
]]></description><link>https://forum.mango-os.com/topic/1479/compound-event-detectors-button</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 13:54:15 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/1479.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 06 Feb 2014 22:47:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Compound event detectors button ? on Tue, 18 Feb 2014 00:36:46 GMT]]></title><description><![CDATA[<p dir="auto">I don't believe there are wrappers to expose the events to the script engine, so your options to access that information directly is probably to either write a module or write wrappers for the scheduled events. (the code solution)</p>
<p dir="auto">Or you could create event handlers for your scheduled events that set virtual points to certain values, then query the virtual point to know the status of the event within the script engine. (the existing solution)</p>
]]></description><link>https://forum.mango-os.com/post/8351</link><guid isPermaLink="true">https://forum.mango-os.com/post/8351</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Tue, 18 Feb 2014 00:36:46 GMT</pubDate></item><item><title><![CDATA[Reply to Compound event detectors button ? on Mon, 17 Feb 2014 17:36:08 GMT]]></title><description><![CDATA[<p dir="auto">Hi, What I currently have in scadabr are events witch are composed with pointValues and time conditions ( scheduled events ). Something like ( pseudocode ):</p>
<p dir="auto">if pointValue is &gt; 1 and scheduled_event_1 is on:<br />
do_something.</p>
<p dir="auto">Well, I have seen both metadata and script data sources and I can include pointValues but ... How can I include in logic the state of scheduled-events state ?</p>
]]></description><link>https://forum.mango-os.com/post/8345</link><guid isPermaLink="true">https://forum.mango-os.com/post/8345</guid><dc:creator><![CDATA[bitelxux]]></dc:creator><pubDate>Mon, 17 Feb 2014 17:36:08 GMT</pubDate></item><item><title><![CDATA[Reply to Compound event detectors button ? on Fri, 07 Feb 2014 13:12:51 GMT]]></title><description><![CDATA[<p dir="auto">ScadaBR has an "scripts" button in main menu bar where it's possible to write scripts for using them in other places.</p>
<p dir="auto">Any way what we really need us to accomplish Compounds Events feature. I will try to achieve that with scripting data source as you propose.</p>
<p dir="auto">This will dificult porting from our current ScadaBR implementations to Mango Automation, but it should be possible.</p>
<p dir="auto">Thank you.</p>
]]></description><link>https://forum.mango-os.com/post/8293</link><guid isPermaLink="true">https://forum.mango-os.com/post/8293</guid><dc:creator><![CDATA[bitelxux]]></dc:creator><pubDate>Fri, 07 Feb 2014 13:12:51 GMT</pubDate></item><item><title><![CDATA[Reply to Compound event detectors button ? on Fri, 07 Feb 2014 00:02:57 GMT]]></title><description><![CDATA[<p dir="auto">Mango Automation does not have compound event detectors although we may add this feature in the near future.</p>
<p dir="auto">You can accomplish the same thing using either Meta Data Points or the Scripting Data Source.</p>
<p dir="auto">I'm not sure what you mean by Scripts Button?  We have a scripting data source that is very very powerful.</p>
]]></description><link>https://forum.mango-os.com/post/8291</link><guid isPermaLink="true">https://forum.mango-os.com/post/8291</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Fri, 07 Feb 2014 00:02:57 GMT</pubDate></item><item><title><![CDATA[Reply to Compound event detectors button ? on Thu, 06 Feb 2014 23:02:02 GMT]]></title><description><![CDATA[<p dir="auto">same with mango-automation-full-core-2.1.0.zip</p>
<p dir="auto">Nor compound events nor scripts buttons</p>
]]></description><link>https://forum.mango-os.com/post/8290</link><guid isPermaLink="true">https://forum.mango-os.com/post/8290</guid><dc:creator><![CDATA[bitelxux]]></dc:creator><pubDate>Thu, 06 Feb 2014 23:02:02 GMT</pubDate></item></channel></rss>
