<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Points using old name after renaming them?]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I am new to Mango and I am really impressed. I bought the license just yesterday, one day after installing. Here is my first question.</p>
<p dir="auto">I have setup a data source with some points called 'HKO - Current Weather'.<br />
Later I renamed the same to simply 'HKO'.</p>
<p dir="auto">When I look at the Point Hierarchy, they still show up with the old name. Is there way to change this? I am just trying to find out the small details before setting up a system with hundreds of data points.</p>
]]></description><link>https://forum.mango-os.com/topic/1414/points-using-old-name-after-renaming-them</link><generator>RSS for Node</generator><lastBuildDate>Tue, 15 Sep 2026 05:41:46 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/1414.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 12 Oct 2013 03:49:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Points using old name after renaming them? on Sat, 12 Oct 2013 09:04:45 GMT]]></title><description><![CDATA[<p dir="auto">Click on the point details icon on the far left of the top menu.  Then click on the "edit data point" icon and you will see the option to change the device name.  In our next release we have combined all these setting into one place to make it much easier to find.</p>
<p dir="auto">Joel.</p>
]]></description><link>https://forum.mango-os.com/post/8006</link><guid isPermaLink="true">https://forum.mango-os.com/post/8006</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Sat, 12 Oct 2013 09:04:45 GMT</pubDate></item><item><title><![CDATA[Reply to Points using old name after renaming them? on Sat, 12 Oct 2013 07:02:46 GMT]]></title><description><![CDATA[<p dir="auto">Hi Joel</p>
<p dir="auto">Thanks for the reply. Clearing the browser cache didn't solve the problem.</p>
<p dir="auto">I am able to rename the data points and in the hierarchy I can see the changes.<br />
But the device name, or the name of the data source, stays the same in the hierarchy, no matter what I change it to in Data Sources.</p>
<p dir="auto">(I am editing this name under HTTP Retriever properties)</p>
<p dir="auto">Alex</p>
]]></description><link>https://forum.mango-os.com/post/8004</link><guid isPermaLink="true">https://forum.mango-os.com/post/8004</guid><dc:creator><![CDATA[AlexHK]]></dc:creator><pubDate>Sat, 12 Oct 2013 07:02:46 GMT</pubDate></item><item><title><![CDATA[Reply to Points using old name after renaming them? on Sat, 12 Oct 2013 05:37:13 GMT]]></title><description><![CDATA[<p dir="auto">Another thing that may be confusing is there are two parts to the name the first part (before the - ) is the Device name which takes the name of the data source by default.  The second part is the name of the data point.  If you look at the point setting on the point details page you can set the device name and the point name.</p>
<p dir="auto">Hope that helps,</p>
]]></description><link>https://forum.mango-os.com/post/8003</link><guid isPermaLink="true">https://forum.mango-os.com/post/8003</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Sat, 12 Oct 2013 05:37:13 GMT</pubDate></item><item><title><![CDATA[Reply to Points using old name after renaming them? on Sat, 12 Oct 2013 05:21:18 GMT]]></title><description><![CDATA[<p dir="auto">Hi Alex,</p>
<p dir="auto">Thanks for the note and I'm glad you are getting started with Mango.  Can you try clearing your browser cache and see if that resolves the issue.</p>
<p dir="auto">Thanks,<br />
Joel.</p>
]]></description><link>https://forum.mango-os.com/post/8002</link><guid isPermaLink="true">https://forum.mango-os.com/post/8002</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Sat, 12 Oct 2013 05:21:18 GMT</pubDate></item></channel></rss>
