<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How do you run Mango as a Windows service?]]></title><description><![CDATA[<p dir="auto">Hi Windows Guru,</p>
<p dir="auto">How do you run Mango as a Windows service? Preferably, it will auto restart whenever the service was stop unexpectedly.</p>
<p dir="auto">BR,<br />
Ricardo</p>
]]></description><link>https://forum.mango-os.com/topic/1378/how-do-you-run-mango-as-a-windows-service</link><generator>RSS for Node</generator><lastBuildDate>Tue, 17 Nov 2026 08:17:24 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/1378.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 16 Aug 2013 10:09:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How do you run Mango as a Windows service? on Fri, 03 Feb 2017 23:52:42 GMT]]></title><description><![CDATA[<p dir="auto">What is your install path.  I think the configuration file for the service is for C:\Mango if it's different you need to edit that before you install the service.</p>
]]></description><link>https://forum.mango-os.com/post/13802</link><guid isPermaLink="true">https://forum.mango-os.com/post/13802</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Fri, 03 Feb 2017 23:52:42 GMT</pubDate></item><item><title><![CDATA[Reply to How do you run Mango as a Windows service? on Fri, 03 Feb 2017 21:52:08 GMT]]></title><description><![CDATA[<p dir="auto">Keith,</p>
<p dir="auto">Please do share the contents of ma.log from Mango/bin/logs/ or Mango/logs/</p>
]]></description><link>https://forum.mango-os.com/post/13801</link><guid isPermaLink="true">https://forum.mango-os.com/post/13801</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Fri, 03 Feb 2017 21:52:08 GMT</pubDate></item><item><title><![CDATA[Reply to How do you run Mango as a Windows service? on Fri, 03 Feb 2017 18:57:20 GMT]]></title><description><![CDATA[<p dir="auto">Joel,</p>
<pre><code>Yes, I can run Mango with the ma-start.bat file.
]]></description><link>https://forum.mango-os.com/post/13798</link><guid isPermaLink="true">https://forum.mango-os.com/post/13798</guid><dc:creator><![CDATA[keith.crenshaw]]></dc:creator><pubDate>Fri, 03 Feb 2017 18:57:20 GMT</pubDate></item><item><title><![CDATA[Reply to How do you run Mango as a Windows service? on Fri, 03 Feb 2017 04:36:30 GMT]]></title><description><![CDATA[<p dir="auto">Can you run it without the service with the ma-start.bat file?</p>
<p dir="auto">You'll want to look in the logs file for errors during start up.  They will be located in /logs/ma.log or sometimes when running as a windows service in bin/logs/ma.log</p>
]]></description><link>https://forum.mango-os.com/post/13789</link><guid isPermaLink="true">https://forum.mango-os.com/post/13789</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Fri, 03 Feb 2017 04:36:30 GMT</pubDate></item><item><title><![CDATA[Reply to How do you run Mango as a Windows service? on Thu, 02 Feb 2017 20:10:50 GMT]]></title><description><![CDATA[<p dir="auto">So I just installed Mango on a Win7 laptop. I followed the directions given to install/run as a service, although the service installed, after started, it stops shortly after. Also, even though the service says it is running, I cannot access the page via localhost:8080. Are there additional steps that are not outlined?</p>
]]></description><link>https://forum.mango-os.com/post/13786</link><guid isPermaLink="true">https://forum.mango-os.com/post/13786</guid><dc:creator><![CDATA[keith.crenshaw]]></dc:creator><pubDate>Thu, 02 Feb 2017 20:10:50 GMT</pubDate></item><item><title><![CDATA[Reply to How do you run Mango as a Windows service? on Fri, 16 Aug 2013 19:35:33 GMT]]></title><description><![CDATA[<p dir="auto">We don't currently have a windows service for Mango but you can make it auto start by placing a link to the ma-start.bat file in your start up folder.</p>
<p dir="auto">Thanks,</p>
<p dir="auto">Joel.</p>
]]></description><link>https://forum.mango-os.com/post/7882</link><guid isPermaLink="true">https://forum.mango-os.com/post/7882</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Fri, 16 Aug 2013 19:35:33 GMT</pubDate></item></channel></rss>
