<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Snmp]]></title><description><![CDATA[<pre><code>[root@dom snmp]# snmpwalk -v 2c -Os localhost -c public .1.3.6.1.4.1.2021.9.1.7
dskAvail.1 = INTEGER: 41659556
[root@dom snmp]# snmpwalk -v 2c -Os localhost -c public .1.3.6.1.2.1.1.1.0
sysDescr.0 = STRING: Linux dom.mks.si 2.6.32-279.14.1.el6.x86_64 #1 SMP Tue Nov 6 23:43:09 UTC 2012 x86_64
<p dir="auto">These two both work from comand line, but being set from Mango snmp data source, only the second works.<br />
Testing OID .1.3.6.1.4.1.2021.9.1.7 (dskAvail.1) says Null.<br />
The data point even raised alarm saying: 'dfree': PDU received with error in OID 1.3.6.1.4.1.2021.9.1.7, text=No such name</p>
<p dir="auto">Any hint is welcome.<br />
Regards, Zdravko</p>
]]></description><link>https://forum.mango-os.com/topic/1317/snmp</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 19:52:35 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/1317.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 05 Apr 2013 15:43:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Snmp on Wed, 15 May 2013 11:06:42 GMT]]></title><description><![CDATA[<p dir="auto">Try to put .0 at the end.</p>
<p dir="auto">Probaj dodati kada testiraš .0 na kraju OID-a</p>
]]></description><link>https://forum.mango-os.com/post/7748</link><guid isPermaLink="true">https://forum.mango-os.com/post/7748</guid><dc:creator><![CDATA[iloncare]]></dc:creator><pubDate>Wed, 15 May 2013 11:06:42 GMT</pubDate></item><item><title><![CDATA[Reply to Snmp on Fri, 05 Apr 2013 20:12:38 GMT]]></title><description><![CDATA[<p dir="auto">Mango the latest, and SNMP 2c version.<br />
Strangely, all other OIDs that I have been using work.</p>
<p dir="auto">Zdravko</p>
]]></description><link>https://forum.mango-os.com/post/7659</link><guid isPermaLink="true">https://forum.mango-os.com/post/7659</guid><dc:creator><![CDATA[Zdravko]]></dc:creator><pubDate>Fri, 05 Apr 2013 20:12:38 GMT</pubDate></item><item><title><![CDATA[Reply to Snmp on Fri, 05 Apr 2013 20:05:15 GMT]]></title><description><![CDATA[<p dir="auto">What versions of Mango and SNMP are you using?</p>
]]></description><link>https://forum.mango-os.com/post/7658</link><guid isPermaLink="true">https://forum.mango-os.com/post/7658</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Fri, 05 Apr 2013 20:05:15 GMT</pubDate></item></channel></rss>
