<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Javascript variable from scriptPoint &quot;value&quot;]]></title><description><![CDATA[<p dir="auto">I'm working on some custom views that need the current value of a particular datapoint available as a JS variable.  If I declare the variable in my JS header info, and then try to update using the form:</p>
<p dir="auto">var x = value;</p>
<p dir="auto">within the script section of the scriptPoint tag, this doesn't update the previously declared JS variable (even though "value" is functional and clearly available based on other tests).  Is there a straightforward method of achieving this?  It doesn't have to utilize the scriptPoint function.  If this isn't possible currently, is there a way to do this through a global script?</p>
<p dir="auto">Thanks,<br />
Craig</p>
]]></description><link>https://forum.mango-os.com/topic/1273/javascript-variable-from-scriptpoint-value</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 19:18:10 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/1273.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 20 Feb 2013 19:49:32 GMT</pubDate><ttl>60</ttl></channel></rss>
