<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Trouble with Comm Ports in ASCII Module]]></title><description><![CDATA[<p dir="auto">I have a working Mango Install running on 32 bit Ubuntu 12.04 (server) headless.</p>
<p dir="auto">I have properly installed librxtx-java and copied the appropriate files to enable serial ports.</p>
<p dir="auto">I am using Moxa Nport 5130A &amp; 5150A Serial Device Servers.</p>
<p dir="auto">I have installed the appropriate drivers and am able to [ cat /dev/ttyr00 ] and received data from my device.</p>
<p dir="auto">When attempting to add a data source in Mango the list of Serial ports only contains "/dev/ttyS0" No other serial port on the system shows up on the list.</p>
<p dir="auto">I have done the following in an attempt to get this working:<br />
verified that /dev/ttr00 is owned by the dialout group<br />
verified that /dev/ttyr00 is read/writable to this group. I have also opened it completely "0777"</p>
<p dir="auto">Is anyone familiar with this module and what stars must be aligned to get serial ports listed in the dropdown?<br />
If available I'd happily review the source code and work my way through it, but I have not found any source for this module?<br />
Is there any possibility of pointing this module to a TCP/IP server instead of a serial port. I'm aware that this is possible under modbus, but my hardware does not support modbus?</p>
]]></description><link>https://forum.mango-os.com/topic/1271/trouble-with-comm-ports-in-ascii-module</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Apr 2026 23:36:36 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/1271.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 16 Feb 2013 05:02:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Trouble with Comm Ports in ASCII Module on Sun, 17 Feb 2013 05:57:08 GMT]]></title><description><![CDATA[<p dir="auto">Regarding your question about TCP, yes, this is possible, but currently not supported in the module.</p>
]]></description><link>https://forum.mango-os.com/post/7515</link><guid isPermaLink="true">https://forum.mango-os.com/post/7515</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Sun, 17 Feb 2013 05:57:08 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble with Comm Ports in ASCII Module on Sun, 17 Feb 2013 05:55:34 GMT]]></title><description><![CDATA[<p dir="auto">Well done. Unfortunately this is a matter of both the usb/serial drivers and the RXTX native library, and so for the most part (barring explicit hacking of these thing) is out of our hands. Some devices work better than others.</p>
]]></description><link>https://forum.mango-os.com/post/7514</link><guid isPermaLink="true">https://forum.mango-os.com/post/7514</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Sun, 17 Feb 2013 05:55:34 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble with Comm Ports in ASCII Module on Sat, 16 Feb 2013 19:17:34 GMT]]></title><description><![CDATA[<p dir="auto">A little more info.</p>
<p dir="auto">I have had some success getting a USB to Serial Adapter to function properly. By that I mean I plugged it in, restarted mango, and it showed up in the list.</p>
<p dir="auto">The device in question is a Model USOPTL4 from B &amp; B Electronics.</p>
<p dir="auto">So far I have attempted to use the Moxa realcom TTY driver in the following environments.</p>
<p dir="auto">KVM/QEMU instance on Ubuntu 12.04 64bit HOST Ubuntu 12.04 32bit GUEST - <em>This install required modification of Moxa Source Code npreal2.c[line ~759 "terminos_locked"]</em><br />
KVM/QEMU instance on Ubuntu 12.04 64bit HOST Ubuntu 12.04 64bit GUEST<br />
Ubuntu 12.04 32bit installed on HP laptop.<br />
Ubuntu 12.04 32bit installed on Dell Dimensions 400 Desktop<br />
Virtualbox instance on Windows 7 64bit HOST Ubuntu 12.04 32bit GUEST<br />
Amazon Cloud using EBS Volume - Ubuntu 12.04 32bit from Ubuntu servers lists<br />
Amazon Cloud using EBS Volume - Ubuntu 12.04 64bit from Ubuntu servers lists</p>
<p dir="auto">I have had similar results on all of the installs. The exception being that I have not connected USB adapters to all of the virtualized installs. Some of the installs show /dev/ttyS0 in the list and some do not.</p>
]]></description><link>https://forum.mango-os.com/post/7513</link><guid isPermaLink="true">https://forum.mango-os.com/post/7513</guid><dc:creator><![CDATA[klemorali]]></dc:creator><pubDate>Sat, 16 Feb 2013 19:17:34 GMT</pubDate></item></channel></rss>
