<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Some suggestions of the Mango operation]]></title><description><![CDATA[<ol>
<li>
<p dir="auto">When adding the BACNet/IP and MSTP data points, can we just press the "Add" button without going down to the bottom of the page to press the save button again. It simplify the operation.</p>
</li>
<li>
<p dir="auto">In setting up users, can I just copy a user profile for other users ? When setting up read access for the data points I need to click on each 'read' to grant the right. Can I have one click on 'read' for all data points ?</p>
</li>
]]></description><link>https://forum.mango-os.com/topic/1261/some-suggestions-of-the-mango-operation</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 19:03:09 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/1261.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 08 Feb 2013 01:32:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Some suggestions of the Mango operation on Fri, 08 Feb 2013 02:11:47 GMT]]></title><description><![CDATA[<p dir="auto">Good suggestions.</p>
<p dir="auto">You can use the user export on the Import / Export page to export the users, you can then copy the export of the user you want to duplicate, rename it and past it back into the  import window and click import.  Once you do it once or twice it's actually pretty easy and fast.</p>
<p dir="auto">Joel.</p>
]]></description><link>https://forum.mango-os.com/post/7489</link><guid isPermaLink="true">https://forum.mango-os.com/post/7489</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Fri, 08 Feb 2013 02:11:47 GMT</pubDate></item></channel></rss>
