<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Help File Errors  ***SOLVED!!***]]></title><description><![CDATA[<p dir="auto">I am trying to import data from a smallish cluster of CAI Webcontrol boards. I can get this data via a wget script url an url to a cgi script on the CAI boards. So I downloaded the newest HTTP module and stuck the file in the web/modules directory. Perhaps I don't need this module to use a local script to gather numeric data via wget?</p>
<p dir="auto">This seems to have broken the "help" icons? I get this error:</p>
<pre><code>
    Document file not found: web/WEB-INF/dox/welcomeToMango.htm
<p dir="auto">I see lots of files in /opt/mango/web/WEB-INF/, including "welcomeToMango.htm" so I am not sure what has happened or why?</p>
<p dir="auto">They seemed to work before I added the HTTP module? I removed the http directory thinking it was the problem but after a restart still does not work.</p>
<p dir="auto">Any ideas on this?</p>
<p dir="auto">Thanks.</p>
<p dir="auto">Tom</p>
]]></description><link>https://forum.mango-os.com/topic/1242/help-file-errors-solved</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 13:07:29 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/1242.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 21 Jan 2013 23:27:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Help File Errors  ***SOLVED!!*** on Tue, 22 Jan 2013 00:15:29 GMT]]></title><description><![CDATA[<p dir="auto">OK switching to the mango directory and starting seems to have cured it. Will edit the <a href="http://ma-start.sh" rel="nofollow ugc">ma-start.sh</a> later.</p>
]]></description><link>https://forum.mango-os.com/post/7414</link><guid isPermaLink="true">https://forum.mango-os.com/post/7414</guid><dc:creator><![CDATA[TomW]]></dc:creator><pubDate>Tue, 22 Jan 2013 00:15:29 GMT</pubDate></item><item><title><![CDATA[Reply to Help File Errors  ***SOLVED!!*** on Mon, 21 Jan 2013 23:38:18 GMT]]></title><description><![CDATA[<p dir="auto">Hi Tom,</p>
<p dir="auto">This error happens when the <a href="http://ma-start.sh" rel="nofollow ugc">ma-start.sh</a> script is run from a location other than the MA home dir.</p>
<p dir="auto">I'm attaching a new <a href="http://ma-start.sh" rel="nofollow ugc">ma-start.sh</a> file that solves this problem.  It will also be included in version 2.0.4</p>
<p dir="auto">Also,  you should be able to use the HTTP retriever to get the data directly from the Webcontrol board without using a wget script.</p>
<p dir="auto">Let me know how this works for you,</p>
<p dir="auto">Joel.</p>
<p dir="auto">Attachment: <a href="http://archive.infiniteautomation.com/forum/posts/downloadAttach/204.page" rel="nofollow ugc">download link</a></p>
]]></description><link>https://forum.mango-os.com/post/7413</link><guid isPermaLink="true">https://forum.mango-os.com/post/7413</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Mon, 21 Jan 2013 23:38:18 GMT</pubDate></item></channel></rss>
