<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Schedule Events]]></title><description><![CDATA[<p dir="auto">I have setup a schedule and set an event handler to turn on a fan in a HVAC system. The issue that I have is that I have 19 fan units that I want to all come on at the same time. Is there a way to group them together so I can set 1 schedule for all of them or do I need to set an event schedule for each fan unit.</p>
]]></description><link>https://forum.mango-os.com/topic/1205/schedule-events</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Apr 2026 15:35:33 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/1205.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 11 Dec 2012 09:15:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Schedule Events on Wed, 12 Dec 2012 21:47:29 GMT]]></title><description><![CDATA[<p dir="auto">Thanks, I will play around with the scripting.</p>
]]></description><link>https://forum.mango-os.com/post/7254</link><guid isPermaLink="true">https://forum.mango-os.com/post/7254</guid><dc:creator><![CDATA[echellis]]></dc:creator><pubDate>Wed, 12 Dec 2012 21:47:29 GMT</pubDate></item><item><title><![CDATA[Reply to Schedule Events on Tue, 11 Dec 2012 10:50:58 GMT]]></title><description><![CDATA[<p dir="auto">In the even handler you should be able to add as many set point events as you want.  In the event handler under scheduled events you should see the name of your event, click on the even and then select set point, configure and save.  Do this for each fan.</p>
<p dir="auto">In Mango Automation there is also a new scripting module that allows you to set multipul points in the system and can handle very complex logic.</p>
<p dir="auto">Joel.</p>
]]></description><link>https://forum.mango-os.com/post/7249</link><guid isPermaLink="true">https://forum.mango-os.com/post/7249</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Tue, 11 Dec 2012 10:50:58 GMT</pubDate></item></channel></rss>
