<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Trouble shooting Installation]]></title><description><![CDATA[<p dir="auto">If you are having trouble starting Mango Automation with the ma-start.bat or <a href="http://ma-start.sh" rel="nofollow ugc">ma-start.sh</a> script here are a few things to check:</p>
<li>MA_HOME Environmental Variable is set to your Mango Install directory (usually not required)</li>
<li>Make sure you have Java JDK 1.7 installed.</li>
<li>JAVA_HOME is set to the Java JDK 1.7 install directory.  On windows usually: C:\Program Files\Java\jdk1.7.0_XX</li>
<li>Nothing else is using port 8080 or change Mango to run on a different port.  See the /classes/env.properties file to set the new port number, read the instructions on how to use the overrides directory.</li>
<p dir="auto">If you still have trouble and you notice that script window briefly pops up and then the window closes: Open a command prompt and run mango from there so the window doesn't close.  Make a post in this forum with the results of the script and we will help you diagnose the issue.</p>
<p dir="auto">Joel.</p>
]]></description><link>https://forum.mango-os.com/topic/1145/trouble-shooting-installation</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 11:21:04 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/1145.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 12 Oct 2012 00:15:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Trouble shooting Installation on Thu, 20 Jun 2013 07:28:06 GMT]]></title><description><![CDATA[<p dir="auto">Hard to know with out a bit more information.  I would recommend starting over with fresh files, make sure you have the latest version.  M2M2_HOME is not needed any more and was for an older version, just JAVA_HOME.</p>
<p dir="auto">You can also call in for support if you need some live help.</p>
]]></description><link>https://forum.mango-os.com/post/7802</link><guid isPermaLink="true">https://forum.mango-os.com/post/7802</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Thu, 20 Jun 2013 07:28:06 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble shooting Installation on Wed, 19 Jun 2013 04:41:01 GMT]]></title><description><![CDATA[<p dir="auto">I have got m2m2 installed and running. When I go to <a href="http://localhost:8080/system_settings.shtm" rel="nofollow ugc">http://localhost:8080/system_settings.shtm</a> I get the page with no values. When I start filling them in and click save I get an error...</p>
<p dir="auto">dojo.html is undefined</p>
<p dir="auto">What am I doing wrong? is there an env var I need to set? (ive set M2M2_HOME and JAVA_HOME)</p>
]]></description><link>https://forum.mango-os.com/post/7801</link><guid isPermaLink="true">https://forum.mango-os.com/post/7801</guid><dc:creator><![CDATA[SESA]]></dc:creator><pubDate>Wed, 19 Jun 2013 04:41:01 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble shooting Installation on Tue, 23 Apr 2013 19:02:20 GMT]]></title><description><![CDATA[<p dir="auto">Attached is a service that I know works on Ubuntu.  Place it in the /etc/init folder and then you can run "service mango start or stop".  You'll have to edit the path in the script to your <a href="http://ma-start.sh" rel="nofollow ugc">ma-start.sh</a> file.</p>
<p dir="auto">Attachment: <a href="http://archive.infiniteautomation.com/forum/posts/downloadAttach/215.page" rel="nofollow ugc">download link</a></p>
]]></description><link>https://forum.mango-os.com/post/7715</link><guid isPermaLink="true">https://forum.mango-os.com/post/7715</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Tue, 23 Apr 2013 19:02:20 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble shooting Installation on Tue, 23 Apr 2013 18:23:05 GMT]]></title><description><![CDATA[<p dir="auto">Joel,</p>
<p dir="auto">Do you have an example of an init script to automatically start mango on boot (i.e. something that would live in /etc/init.d/, that I could drop in and configure with chkconfig ), and stop it on command?</p>
<p dir="auto">I have created one, and I can get the system to start, but I don't have a command to stop it.  With a default tomcat install I get a <a href="http://startup.sh" rel="nofollow ugc">startup.sh</a> and a <a href="http://shutdown.sh" rel="nofollow ugc">shutdown.sh</a> which each do their respective jobs, why is there no <a href="http://ma-shutdown.sh" rel="nofollow ugc">ma-shutdown.sh</a>?</p>
]]></description><link>https://forum.mango-os.com/post/7714</link><guid isPermaLink="true">https://forum.mango-os.com/post/7714</guid><dc:creator><![CDATA[amol2670]]></dc:creator><pubDate>Tue, 23 Apr 2013 18:23:05 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble shooting Installation on Tue, 09 Apr 2013 04:39:24 GMT]]></title><description><![CDATA[<p dir="auto">Java 7 should be fine.  Make sure your JAVA_HOME environmental variable is set to the Java JDK install directory. On windows usually: C:\Program Files\Java\jdk1.X.0_XX</p>
]]></description><link>https://forum.mango-os.com/post/7667</link><guid isPermaLink="true">https://forum.mango-os.com/post/7667</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Tue, 09 Apr 2013 04:39:24 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble shooting Installation on Mon, 08 Apr 2013 06:08:40 GMT]]></title><description><![CDATA[<p dir="auto">I use the java7, maybe is this problem, show error message error:missing 'server' jvm at "C:\Program Files\Java\jre7\bin\server\jvm.dll",but my java directory is "C:\Program Files\Java\jre7\bin\client \jvm.dll",if is this problem,if i need install java6,thanks.</p>
]]></description><link>https://forum.mango-os.com/post/7664</link><guid isPermaLink="true">https://forum.mango-os.com/post/7664</guid><dc:creator><![CDATA[hussam]]></dc:creator><pubDate>Mon, 08 Apr 2013 06:08:40 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble shooting Installation on Fri, 22 Mar 2013 09:03:16 GMT]]></title><description><![CDATA[<p dir="auto">thanks!<br />
the trouble was the variable for java</p>
]]></description><link>https://forum.mango-os.com/post/7600</link><guid isPermaLink="true">https://forum.mango-os.com/post/7600</guid><dc:creator><![CDATA[elah]]></dc:creator><pubDate>Fri, 22 Mar 2013 09:03:16 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble shooting Installation on Fri, 22 Mar 2013 07:05:13 GMT]]></title><description><![CDATA[<p dir="auto">Did you install the Java JDK and set the Environmental variable?  Please provide more details.</p>
]]></description><link>https://forum.mango-os.com/post/7599</link><guid isPermaLink="true">https://forum.mango-os.com/post/7599</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Fri, 22 Mar 2013 07:05:13 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble shooting Installation on Thu, 21 Mar 2013 22:18:34 GMT]]></title><description><![CDATA[<p dir="auto">Hi!<br />
I'm trying to install mango automation but I can't<br />
it appears on my window:</p>
<p dir="auto">Using C:\Program Files\Mango Automation\m2m2-core-2.0.6 as MA-HOME<br />
the system can not find the file specified.<br />
Using Java at java<br />
"java" is not recognized as an internal or external command,<br />
program or? batch file</p>
<p dir="auto">Thanks for your attention<br />
Elah</p>
]]></description><link>https://forum.mango-os.com/post/7594</link><guid isPermaLink="true">https://forum.mango-os.com/post/7594</guid><dc:creator><![CDATA[elah]]></dc:creator><pubDate>Thu, 21 Mar 2013 22:18:34 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble shooting Installation on Sat, 02 Mar 2013 01:10:07 GMT]]></title><description><![CDATA[<p dir="auto">Trying to evaluate Mango.<br />
I am using Ubuntu. Installed JDK and Tomcat6. Tomcat6 works fine. Then extracted Mango to the Tomcat6/webapps/ROOT.<br />
Now browsing to localhost/8080 gives error 404.<br />
Looked in the Mango log. Got</p>
<p dir="auto">INFO  2013-03-01 10:27:45,244 (org.springframework.web.context.ContextLoader.initWebApplicationContext:209) - Root WebApplicationContext: initialization completed in 1351 ms<br />
INFO  2013-03-01 10:27:45,244 (com.serotonin.mango.MangoContextListener.contextInitialized:79) - Mango context starting<br />
INFO  2013-03-01 10:27:45,807 (com.serotonin.mango.db.DerbyAccess.initializeImpl:72) - Initializing derby connection manager<br />
INFO  2013-03-01 10:27:46,713 (com.serotonin.mango.MangoContextListener.contextDestroyed:120) - Mango context terminating<br />
INFO  2013-03-01 10:27:46,714 (com.serotonin.mango.db.DerbyAccess.terminate:93) - Stopping database<br />
INFO  2013-03-01 10:27:46,734 (com.serotonin.mango.MangoContextListener.contextDestroyed:142) - Mango context terminated</p>
<p dir="auto">I assume that derby is not installed or not working.</p>
<p dir="auto">Any ideas? Should I ignore derby and use MySQL?</p>
]]></description><link>https://forum.mango-os.com/post/7551</link><guid isPermaLink="true">https://forum.mango-os.com/post/7551</guid><dc:creator><![CDATA[JackChad]]></dc:creator><pubDate>Sat, 02 Mar 2013 01:10:07 GMT</pubDate></item></channel></rss>
