<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mango without USER access]]></title><description><![CDATA[<p dir="auto">Hi. I need to setup Mango without USER access. Just start browser with <a href="http://localhost:8080" rel="nofollow ugc">http://localhost:8080</a> and immediately see online data. Is it possible ?</p>
]]></description><link>https://forum.mango-os.com/topic/103/mango-without-user-access</link><generator>RSS for Node</generator><lastBuildDate>Fri, 09 Oct 2026 17:42:58 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/103.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 08 Sep 2008 19:11:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Mango without USER access on Tue, 16 Sep 2008 16:21:36 GMT]]></title><description><![CDATA[<p dir="auto">The discussion board software apparently removes things it considers suspicious. The content of the &lt;a&gt; link should be:</p>
<pre><code>
href="#" onclick="mangoLogin()"
]]></description><link>https://forum.mango-os.com/post/2285</link><guid isPermaLink="true">https://forum.mango-os.com/post/2285</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Tue, 16 Sep 2008 16:21:36 GMT</pubDate></item><item><title><![CDATA[Reply to Mango without USER access on Tue, 16 Sep 2008 16:19:00 GMT]]></title><description><![CDATA[<p dir="auto">Actually, on second thought this would actually be fairly easy. All you'd have to do is create a page - hosted anywhere - that embeds login credentials for the user you want to expose. Just put a link on a page that maybe looks like this:</p>
<pre><code>
&lt;a  &gt;Mango&lt;/a&gt;
&amp;lt;div style="display:none"&amp;gt;
  &amp;lt;form id="mangoLoginForm" action="&amp;lt;mango url&amp;gt;/login.htm"&amp;gt;
    &amp;lt;input type="hidden" name="username" value="anonymousUsername"/&amp;gt;
    &amp;lt;input type="hidden" name="password" value="anonymousPassword"/&amp;gt;
  &amp;lt;/form&amp;gt;
&amp;lt;/div&amp;gt;
&amp;lt;script type="text/javascript"&amp;gt;
  function mangoLogin() {
      document.getElementById("mangoLoginForm").submit();
&amp;lt;/script&amp;gt;
<p dir="auto">(Caveat: the above code was just typed out entirely untested. Should generally work, but please forgive any bugs.)</p>
<p dir="auto">When the link is clicked, the hidden form will be submitted and the user should be automatically logged in. Note that they will have a logout button - not sure if that matters to you.</p>
]]></description><link>https://forum.mango-os.com/post/2284</link><guid isPermaLink="true">https://forum.mango-os.com/post/2284</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Tue, 16 Sep 2008 16:19:00 GMT</pubDate></item><item><title><![CDATA[Reply to Mango without USER access on Sun, 14 Sep 2008 18:41:41 GMT]]></title><description><![CDATA[<p dir="auto">Java isn't problem for me but I need to know where is stored (programmend) user rights algoritmus to make changes.<br />
thanx</p>
]]></description><link>https://forum.mango-os.com/post/2283</link><guid isPermaLink="true">https://forum.mango-os.com/post/2283</guid><dc:creator><![CDATA[dusky]]></dc:creator><pubDate>Sun, 14 Sep 2008 18:41:41 GMT</pubDate></item><item><title><![CDATA[Reply to Mango without USER access on Fri, 12 Sep 2008 01:35:13 GMT]]></title><description><![CDATA[<p dir="auto">Are you a J2EE developer at all? If not there's probably a steep learning curve ahead.</p>
]]></description><link>https://forum.mango-os.com/post/2282</link><guid isPermaLink="true">https://forum.mango-os.com/post/2282</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Fri, 12 Sep 2008 01:35:13 GMT</pubDate></item><item><title><![CDATA[Reply to Mango without USER access on Mon, 08 Sep 2008 20:26:55 GMT]]></title><description><![CDATA[<p dir="auto">Could you help me which file (code) I have to change ? A lot of thanks. Dusky</p>
]]></description><link>https://forum.mango-os.com/post/2279</link><guid isPermaLink="true">https://forum.mango-os.com/post/2279</guid><dc:creator><![CDATA[dusky]]></dc:creator><pubDate>Mon, 08 Sep 2008 20:26:55 GMT</pubDate></item><item><title><![CDATA[Reply to Mango without USER access on Mon, 08 Sep 2008 19:50:30 GMT]]></title><description><![CDATA[<p dir="auto">You'll need to do a bit of coding... I'd recommend creating a page that does an automatic login of a user to which you've given appropriate permissions.</p>
]]></description><link>https://forum.mango-os.com/post/2278</link><guid isPermaLink="true">https://forum.mango-os.com/post/2278</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Mon, 08 Sep 2008 19:50:30 GMT</pubDate></item></channel></rss>
